BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Downpipe reccomendation and Syd Install
      04-28-2011, 07:08 AM   #1
antferrrny
Drives: 335i Coupe
Hi All!
I have just bought a 07 335i a couple of months ago and have decided that I want to do some simple mods. Thought that this might be a good opportunity to say hi! And get some advice....
I'm thinking of starting of with a DCI, DP and then Procede...
Any reccomendations on what DP is the best forour RHD vehicles? Agency or AR Design? Any other options?
Also any ideas of installers in Sydney that have experiance in installation of DPs?
Thanks for your help guys.
Cheers,
Anthony
      04-28-2011, 08:11 AM   #2
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
808
Drives: a black car
Hi Ant,
Go procede first then the rest of the boltons...
Many people have been happy with AR design (both catless and catted) downpipes. You should come across many user reviews with a bit of browsing.
      04-28-2011, 07:10 PM   #3
WOPALX
WOPALX's Avatar
Australia
86
Drives: 335i Sedan
Originally Posted by bmroxm5 View Post
Hi Ant,
I'd recommend catted DPs OR catless followed by choice of your own hi-flow cat.
+ 1
Also Adrian from Vishnu in Sydney will be able to advise on DP installers.
Vishnu PROcede V5 | VK Motorworks FMIC | AR Design OCC | Forge DV's | Bilstein PSS9 | M3 Lower Control Arms & Caster Rods | Quaife LSD | HiTech Exhaust | BMW Performance Illuminated Door Sills | BMW Performance Gear Selector & Boot | BMW Performance E-Brake Cover
      04-29-2011, 05:10 AM   #4
antferrrny
Drives: 335i Coupe
No worries, thanks for the help guys!
The only reason I wanted DP's and DCI's first was because I'm after a bit more sound, and thought that I got them after the Procede I might be a bit dissapointed with the performance jump.
But withall this hype, I might just need to take the plunge!
      04-29-2011, 08:16 PM   #5
808
Drives: a black car
You're correct in thinking that you'll be disappointed with the performance jump after adding DPs and DCIs to your procede...
stock -> procede has a massive performance jump for relatively little cost that is hard to replicate with any other type of mods.
If you're only after sound, then it shouldn't really matter if you get performance or not cause you're doing it for the sound not the ponies?
      02-26-2013, 06:10 PM   #6
kaitan
kaitan's Avatar
73
Drives: The Dark Side VAG TDI Biturbo
Originally Posted by antferrrny View Post
Hi All!
Cheers,
Anthony
Who you ended up sending it too to get this fix?
      02-27-2013, 02:20 AM   #7
Kiwi Peter
Kiwi Peter's Avatar
New Zealand
162
Drives: E92 M3 2012 Edition 500
Hi All!
Cheers,
Anthony
Hi there Anthony
Give me a ring or swing by i can help you out with whatever you need
peter @ Advan
02-96483366
