Driver's door speaker grille
05-07-2011, 10:06 PM | #1 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
I know this sounds silly, but is there a trick to putting the grille back in? I popped it off to take a look at something, and broke two tabs on my original one after I tried putting it back in.
I got a replacement, and I'm aware that one tab specifically goes in one spot, but it just doesn't want to clip in. I'm afraid of applying too much pressure and breaking it again. I read one thread claiming you have to take the door panel off, but it sounded like that was for securing the fasteners holding the speaker itself in.
The i8 needs a V8 amirite?
05-07-2011, 11:11 PM | #2 |
253
Rep 7,089
Drives: '06 AW 330xi
I never knew the grill came off. I always thought you had to remove the speaker from behind the door panel.
I guess your only solution is glue. |
05-07-2011, 11:32 PM | #3 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
It's held in by tabs, and they sell replacements, so I can't imagine glue is the only solution.
05-07-2011, 11:54 PM | #4 |
Rep 1,203
When I replaced my covers to "M3" Speaker covers....I had to take off the door panel and remove the speaker. Its not hard to remove the door panel at all. If you careful you shouldn't need new door panel clips.
05-08-2011, 12:00 AM | #5 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Yea, I was thinking I'd have to remove the speaker because it is slightly off center, and that's what's pressing against a couple tabs.
I don't have that clip removal tool, though...not sure if I should attempt it.
05-08-2011, 09:51 AM | #6 |
Rep 1,203
You really dont need one, it helps but you can accomplish it without using a little bit of course...If your going to give it a shot start at the bottom and work your way around the door panel...Btw their are three screws behind the trim
05-08-2011, 11:03 AM | #7 |
1911
Rep 13,104
There are a couple of DIY on removing the panel
They are in the DIY section one for removing the rearview mirror.
There is also a BSW video on replacing the speakers online , it does show you how to remove the panels on the coupe though. Last edited by ctuna; 05-08-2011 at 09:15 PM.. |
05-08-2011, 04:50 PM | #8 |
Rep 81
I just took my door panels off today to install speakers.
I used a plastic putty knife from Home Depot to pry it open with no problems. I did have a hell of a time getting the door panels back on though. |
05-08-2011, 04:55 PM | #9 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
I decided to do it right and ordered this:
http://www.amazon.com/Actron-CP5011-...4891700&sr=8-1 It'll be here Tuesday, and hopefully I can get it all situated without breaking anything.
05-08-2011, 09:43 PM | #10 | |
Rep 6,845
Drives: 2018 Audi RS5 coupe
05-08-2011, 10:19 PM | #11 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
heh, I think I'll throw it in the toolbox...never know when it might come in handy.
05-10-2011, 07:54 AM | #12 |
Rep 3,969
Let me know if anyone figures out how to reinstall the grilles without removing the door panels. I know that the grille is irregularly shaped and that there must be a certain position it wants in order to fit correctly.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
05-10-2011, 08:55 AM | #13 |
Rep 271
It's nearly impossible. Just remove the door panel. Much easier. And you will only get ticked off trying otherwise. I know this from personal experience.
05-10-2011, 10:20 AM | #14 |
Rep 6,845
i have
but it is a huge pain in the ass if you look at the tabs one of them is smaller than the others find the corresponding hole in the door trim but you have to push in all the tabs as you install the cover basically just enough to clear the rim then once they pass the rim they snap into place it can take you ages to get it right or you take off door trim and take out speaker and do it the easy way
05-10-2011, 12:41 PM | #15 |
Rep 3,969
Well, for what its worth, I figured out the correct orientation of the grille. One of the tabs has a "tongue" on the outside, which fits into a single corresponding hole with a notch cut into it. See pics. I got it 80% of the way in, which is OK for now. Looks a lot better. I will remove the panels in about a month, when I replace the door speakers.
05-10-2011, 06:38 PM | #16 | |
Rep 81
05-10-2011, 06:50 PM | #17 |
Rep 3,969
I'm going to install Hybrid Audio L3SEs, without tweeters!
05-10-2011, 07:28 PM | #19 |
Rep 3,969
That's the plan!
05-11-2011, 01:49 AM | #21 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Ya, so I got around to fixing it today. I bought some trim removal tools off amazon and followed a diy on here (it was for the door lock actuator, but had good pictures of where the tabs are).
Anyways, after doing it the right way, I think it's safe to say it's near impossible to do it without taking the panel off. The speaker sits inside the grille tabs and pushes them into the baffle. Took like 20 minutes.
