Amp mounting tips, please
05-09-2011, 08:37 AM | #1 |
Rep 55
Fellas,
I'm ready to install my MS-8 into my e90 sedan. It needs to sit in close proximity to the Logic 7 amp, as I've crimped quick disconnects to both sides of the L7 harness and the input/output wires of the MS-8. Pulling out all of the left side trunk lining, I'm trying to figure out how to secure the MS-8, without impinging on the various vacuum lines, wiring harnesses, and whatnot that resides back there. I'm thinking of fashioning an erector set-like frame to attach to the metal struts on the left side of the trunk, upon which to mount the MS-8, which will mount vertically under the trunk lining on the left side of the trunk above the L7 amp. I don't want to lose trunk space using the CD changer kit, as my golf clubs and other items might not fit. Any thoughts on solutions? Alternative placements? |
05-09-2011, 11:43 AM | #2 | |
Rep 3,969
As far as mounting it above the amp, vertical... are you sure there is enough room to do that?
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
05-09-2011, 12:25 PM | #3 |
Rep 55
Yep, plenty of real estate to mount the MS-8 long ways up and down above the L7 amp. It would sit exposed, above the trunk liner. The trick is building a support structure under the liner that will hold it, above the various wires, lines, etc.
I too looked hard at the pan below the floor. It would fit, except the depression where the handle of the floor piece is in the way. Maybe Technic has a trick up his sleeve? |
05-09-2011, 02:08 PM | #4 | |
2288
Rep 13,001
05-09-2011, 02:47 PM | #5 |
Rep 3,969
^^^ Yep, that's the one I remember seeing!
Come on T, can't just post a pic without giving some advice on any necessary mods in order to get the trunk lid to shut completely....
05-09-2011, 03:20 PM | #6 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
no shaving or any mods
just fits right in
05-09-2011, 03:26 PM | #7 |
Rep 55
When I cribbed that idea from you guys and tried it, I couldn't get the latch recess on the floor cover to not hit the MS-8. Is the trick in the little angle you threw in there? Now I gotta get home and shoehorn it in there again.
05-09-2011, 03:35 PM | #8 |
253
Rep 7,089
Drives: '06 AW 330xi
Is the M3 floor the same as the 335? I know my 330xi doesn't look like that.
05-09-2011, 04:18 PM | #9 | |
2288
Rep 13,001
It cannot be seen in that photo but that is what I do as well. In the 328i trunk the plastic tray is too shallow for a MS-8 to be installed there. |
