19x8.5 & 19x10 work on XI?
05-11-2011, 10:50 AM | #1 |
203
Rep 14,190
The wheel specs are:
19x8.5 +32 : FRONT 19x10 +20: REAR Does anyone know if these will work on a e92 335 XI? I'm concerned about the differential and am pretty sure there is just a limited difference in size I can have on the XI. What do you think? edit: I know to to keep under a 1% rolling diameter, im not sure if this is possible with an 1 1/2 width difference. |
05-11-2011, 10:53 AM | #2 |
Rep 7,433
Yes, wheel width does not matter, it has everything to do with the tires. You can run a 235/35/19 up front with either 265/30/19 or 275/30/19 in the rear. 275 would be a better match but I'm not sure you can run that big of a tire with those wheel specs.
