what do about having a spare?
05-22-2011, 03:50 PM | #1 |
alpine white
13
Rep 342
So I'm thinking of switching to non-rft tires but I don't know what to do about a spare. Do I need to have a full size spare so x-drive won't get messed up or can I just get a donut tire. I'm guessing full size but that seems to be a bit of a hassle since it'll take up so much room in the trunk.
so what have you guys done about a spare in your xi's? (besides just having that repair kit thing). |
05-22-2011, 05:34 PM | #2 | |
Rep 5,627
Tom |
05-22-2011, 08:51 PM | #3 |
alpine white
13
Rep 342
pretty much never. only problem I ever had was a nail in one of my rft's which wasn't bad at all since it didn't even cause any air leakage.
This is more of a precautionary thing so I'm wondering what other people do. |
05-23-2011, 09:39 AM | #5 |
alpine white
13
Rep 342
I know most people just have the mobility kit and thats good enough but I'm wondering what I should do for having a spare if I want. Does it have to be the same size/diameter as the other ones since it's xi or what?
05-23-2011, 11:35 AM | #6 |
253
Rep 7,089
Drives: '06 AW 330xi
Doesn't the mobility kit come with that gunk stuff to "patch" a tire temporarily?
I've heard that stuff will damage TPMS sensors....although if it is an OEM kit, I'm sure BMW has come up with some alternative. This is a very last resort option. You can keep a donut in the car and when you have to mount it in the event of a flat, you can disable your AWD system by pulling fuse 20 on N52s and 26 on N54s. However pulling this fuse will disable DSC, DTC, EBD, ABS, the wheel angle sensor, the speedo, the gas gauge will fluctuate, and tons of shadow faults will be stored. Also the wipers don't stop moving....you can't control the speed either. I just use BMW Assist. |
05-23-2011, 11:59 AM | #7 | |
Rep 5,627
But if you have room for a spare and don't mind the expense, you might check this out: http://www.bavauto.com/se1.asp?dept_id=323 Tom |
05-23-2011, 04:56 PM | #8 |
Rep 28
The spare tire kit is just as big as one of the take off stock wheels, just clean and secure one wheel. I'm always on highway and can't take a chance on repair kits. It all depends how much and where you drive, safety first!!!
05-23-2011, 07:14 PM | #9 |
Rep 181
Does the wheel have to be a certwin diameter?
To answer your question if the sparr has to be the same size as the regualar wheel. The answer is: the spare diameter has to be within 1% of the normal tires diameter. This is because of the xdrive or xi awd system could be damged if not within 1%. Idk how true this is because i havent tested it but its read everywhere ive looked.
2008 335XI E90 // SPORTS // PREMIUM // COLD WEATHER // LOGIC 7 // BLACK DAKOTA LEATHER ON BLACK SAPPHIRE // I-DRIVE // VMR V701 // LED BLACKLINES SMOKED // KWV1 // INJEN DCI // JB4 // LED ANGELS //
05-23-2011, 08:51 PM | #10 |
253
Rep 7,089
You guys are aware that our cars don't come with a jack right? So you need to buy a jack too.
05-24-2011, 03:38 PM | #11 |
Rep 24
plug kit + compressor + space saver spare in the m3
space saver spare in the 335xi - and running on one plugged RFT.
David
2003.5 e46 M3cic | 2004 e83 | 2006 b7 2.0T CVT (sold) 2008 e90 335xia 2009 Sienna XLT Limited | 2003 Honda Pilot EXLRES (sold) |
06-04-2011, 07:14 PM | #14 |
Rep 289
Get the BMW Emergency Tire Kit from Tischer. It's listed for an E60, but it's the same diameter as our cars. Comes with the wheel, tire, jack, wheel block, and lug wrench for like ... 250-300 I think it was? Had a sidewall blowout (rendering a compressor/slime/patching in general useless) and have had this since just in case.
06-05-2011, 01:52 AM | #15 |
9
Rep 40
I got one of these, does the trick.
http://www.bimmerzone.com/mm5/mercha...IM-SST-E90-KIT Bimmerzone was very helpful by email, good place to buy from. |
06-09-2011, 09:53 PM | #16 |
Rep 9
spare
I switched to non rft.I got full size tire plus rim from tirerack.Oem jack from e-bay and lug wrecnh from walmart.You have to figure out how to secure it.Mind you it takes up lot of space in the trunk.
