BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Strange noise at 55mph after staggered wheels installed. Need your Help.
      05-29-2011, 09:56 PM   #1
328xihalogen
Drives: 328xi
So I took off my stock 16" RFT wheels and put on a set of 225/40/18front and 255/35/18rear. I went for a drive and it all seemed fine when I was driving 65mph on a toll road. then on the way back, I was doing slower speed, I notice a very obvious hummingg like noise when the car as doing 55mph. The noise is like all over in the car. I can't really locate it to the wheels but since this is the first time I heard such noise, my suspicion went to the wheels. But I can't think why staggered wheels would cause such noise. I thought maybe the wheels are not balanced as I got them second hand, but I did not feel any vibration at the 55mph speed. I understanding is if the wheels are not balanced then there should be some vibration at higher speed. Now the only other possibility left to me is the resonance; maybe this set of wheels cause resonance at that particular speed? But again, the wheels are on 162 rims which I think are quite common on Xis. So I just don't know what is the causing the noise and I don't know if I should keep driving it as maybe it caused further problems. Any suggestion/opinions would be greatly appreciated!
      05-29-2011, 11:03 PM   #2
fdriller9
Drives: '06 AW 330xi
2006 330xi  [6.44]
What tires do you have? The tires on my 19s produce a lot of road noise/humming.
Im running bf goodrich tires...the model escapes me right now though.
      05-30-2011, 04:46 AM   #3
328xihalogen
Drives: 328xi
Thanks for your reply. The tires are Michelin Pilot Sport A/S Plus. I did not choose these tires. They came with the rims I bought. The noise are not road noise. It starts from 50mph and most obvious at 55mph then goes away at 60mph. The noise was so loud than when i first noticed it, I had to pull over to make sure the wheels were not losen!
      06-01-2011, 08:32 AM   #4
fdriller9
2006 330xi  [6.44]
Maybe they need to be rebalanced. Make sure there are no bends or anything like that.
      06-01-2011, 04:37 PM   #5
C ///M
C ///M's Avatar
Drives: '04 M3 & '07 X3 M-Sport
I'd contact whoever you bought the wheels/tires from...
      06-09-2011, 09:43 AM   #6
kkrriiss
Drives: 2011 328xi sedan
If the tires were used check to make sure that the tread wear hasn't worn down to the indicator in certain spots. that may cause it too.
