Low boost with Procede autotune
06-05-2011, 01:44 AM | #1 |
Rep 436
Hey guys,
I've had my procede for a awhile. I reverted to v5 12-17 today and went out to get autotune going. Initial settings were what map 1 come with. After a few 3rd gear pulls, the car has autotuned to 11psi and 100% IC (that is what the gauges read). I always fuel with 93 oct either BP or Shell. The temps were around 70 with 65% humidity. My mods are in my sig, but I believe these numbers are very low compared to other autotuned v5s here My car has 17k miles currently. Should I be looking at maybe replacing plugs already? |
06-05-2011, 11:25 AM | #3 | |
Rep 480
06-05-2011, 11:31 AM | #4 |
Rep 3,730
You could check for a boost leak, see if your intercooler pipe came off. Happened to me once and I couldn't boost over 12 psi.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
06-05-2011, 11:40 AM | #5 |
3441
Rep 79,211
06-05-2011, 11:51 AM | #6 |
Rep 147
11psi is too low. I run the same mods + FMIC and my car autotunes to 15psi.
See http://www.youtube.com/watch?v=wz_rCicw30E
[SIGPIC][/SIGPIC]
06-05-2011, 06:07 PM | #7 |
Rep 436
I dont think I have a boost leak. I went to the dragstrip today and ran 13-14psi all day with no problems (with autotune off). I've changed the agression to 3 and will see what it autotunes to.
06-05-2011, 06:09 PM | #8 | |
3441
Rep 79,211
Try re-uploading the firmware, resetting adaptations as well. You should log your duty cycles that will also show if you have a boost leak, procede will only increase duty cycles by about 12% extra for safety. |
06-06-2011, 11:25 AM | #10 |
Rep 79
I would also make sure to have your laptop plugged in when you are reloading the firmware/maps. I had nothing but problems with low boost, and it was because I wasn't plugging my laptop in and the firmware was getting corrupted. If that doesn't help, you could have a problem with the vacuum lines controlling your wastegates. I would check to see if there are any cracked or worn out lines. If the above doesn't help, I would consider getting a pressure test done on your system to make absolute sure you don't have a boost leak.
06-06-2011, 12:05 PM | #11 |
65
Rep 1,708
stock IC will make a big difference. You could potentially autotune to lower boost with just DPs, then without. Did you log at the drag track... what were your times? Also depends on how your are doing your autotune runs... back to back no good cause of heat soak.
It does seem a little low for 93oct and I would expect a car or gas issue. Put some higher octane in the tank and see what happens. I did this cause I was autotuning very low with v4 just to confirm the situation, but i have very extreme conditions with weather and octane. The difference between 96oct and 91oct with same ambient temps was about 3psi+ |
06-06-2011, 01:56 PM | #12 |
Rep 4,635
reset adaptations, i had the same problem and did that. worked wonders
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
06-06-2011, 02:22 PM | #13 |
3441
Rep 79,211
06-06-2011, 03:26 PM | #14 |
Rep 436
Thanks for all the suggestions. I always reset adaptations when updating firmware/maps. I couldn't log at the track since whenever I launched, my laptop would crash (Running Win7 on my MacBook).
The times weren't bad, I think. I switched to Map2 and turned autotune off. Boost was at 14psi with IC set at 50%. Best run while the car was cold was a 13.3 with 107mph trap. As the day got warmer, my traps went down (all the way to 103). The in dash boost gauge was pretty much around 13-14 psi all day long, so I don't believe it to be a boost leak. EDIT: Now that I think of it, the 3 autotune passes were done back to back on 70+ weather, so maybe heat soak on the stock IC was the cause. |
