Rear Seatbelt Tensioner Fault Code
06-20-2011, 08:45 PM | #1 |
Rep 12
I'm having a problem getting the airbag light and seatbelt light to go out. It was in a wreck that deployed the driver airbag so I replaced the airbag, clockspring, driver tensioner along with the rear tensioners. The code won't clear using my Bavarian Tool because it says there is a fault in the left rear tensioner. I thought well maybe I got a defective tensioner so I swapped sides to check but it still said the left rear fault.
Does anybody have a direction to point me? Does the computer really need to be replaced? I hear both ways. Thanks |
06-21-2011, 08:49 PM | #2 |
Grozniy
179
Rep 2,602
Yes. Your computer needs to be reset. Google myairbags they can reset your module for about $50.
For about the same price you can get a used one.
-fatman
06-23-2011, 06:30 PM | #4 |
Rep 12
06-23-2011, 07:37 PM | #5 |
216
Rep 1,794
Drives: 06' E90 330, 20' F97 X3m
You can reprogram the control box up to three times and then it needs to be replaced. You definitely have a open circuit if it's not resetting and telling you there's a fault.
LIVE FAST..DRIVE FASTER!! |
05-10-2012, 03:23 PM | #6 |
Rep 9,097
Sorry to bring this topic back to life.
My car has been involved in accident, where driver side airbag was deployed and so tensioner of driver side. It was minor accident and car took the impact from the front driver side (right in UK). Now car has been repaired. Driver side airbag and driver side tensioner was changed. Car was giving three errors: 93B2: Safety Battery Terminal 93B5: Belt tensioner rear left 93B6: Belt tensioner rear right Since I was the only one in the car when accident happened. I wonder why is it giving error of rear L and R tensioners and not passenger side? Is it normal practice for BMW cars to fire all tensioners in event of accident. (and if yes why not passenger side was deployed) I thought changing battery safety terminal may allow me to reset all codes. So BST (battery safety terminal) was bought from the dealer and using inpa, airbag module was reset. 93B2 code has gone but other two (about rear L and R tensioners) are still there. Has anybody come across this scenario? Is it must to change those, or during repair garage staff may have played with rear tensioner wires? Any suggestions / findings?
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
05-11-2012, 12:57 AM | #7 | |
Rep 265
05-11-2012, 01:34 AM | #8 | |
Rep 9,097
I appreciate BMW is one of the safest car, however changing all tensioners after accident..... hmmmm let me think, a good money making scheme. Thanks charles for your reply.
