2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Will 18 inch 42mm offset wheels fit my 550i Xdrive (sports pack)
      06-24-2011, 02:51 PM   #1
e92bmw
Drives: 335i
2007 335i coupe  [0.00]
^^I was wondering if it would fit, I have some from my x5's Winter setup.
Thanks
      06-24-2011, 10:03 PM   #2
jlgwu
9
Drives: '18 440i GC X-Drive M Sport
You'll need some more info before being able to determine fit.
Centre bore size. For the F10, it's 72.6mm. I've heard that the SUV's have a centre bore of 74.1mm. You'll need to confirm this. If this is the case, you can always use a hubcentric adapter ring to make it fit.
On the offset, it'll depend on the width of the rim. As a reference, the 18x8 rims on an F10 have an offset of 30mm.
Here's a link to a wheel offset calculator. You can use to see if the new rims will work. Just use your stocks as reference.
http://www.1010tires.com/wheeloffsetcalculator.asp
5post
