Procedev5 - VANOS/Fuel Pressure codes, Never logged before, suggestions?
06-30-2011, 04:04 PM | #1 |
Rep 1,035
So on a spirited drive home today i got 4 codes...
12544 - Boost deactivation limp mode (caused by another code) 10887 - Outlet VANOS Variable Cam Control Test 10722 - Fuel Injector Rail Pressure Sensor Signal 10738? I thought it was ..38 but when I looked up the codes this doesnt exist. Based on the other codes my guess is it was a 9 because 10739 is "Fuel Pressure Sensor, Electrical" which would make sense. Anyways I have never data logged before but have my laptop setup to do so. Are there any suggestions as to fields I should log? I would at the least like to log fuel pressure to see how that holds up at high RPM's (HPFP was already replaced under recall). Does anyone know if that VANOS code is the one people commonly post about on here? I have read that some fix the issue by removing it and spraying with carb cleaner. I have done a little searching on the forum but it is still my first time doing any logs for the purpose of trying to replicate/diagnose any codes so any suggestions would be of help! Your thoughtful responses are greatly appreciated! |
06-30-2011, 04:11 PM | #3 | |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Looks like a call to the dealership is in order. Leave the codes in there and just remove the Procede. It's not tune related. |
06-30-2011, 04:26 PM | #4 | |
Rep 1,035
If the car is completely out of warranty is it worth taking procede out? They couldnt claim that would mess with the fuel pump would they? BTW ive been trying to call your shop lately but the number is always busy. Robert (i believe) took care of my procede a few months ago unlocking the vin and held onto it while you finished up a newer firmware to fix some sort of "fart" sounding issue as he described lol.. Anyways, i was under the impression that one of the gauge modes was "Boost AND Oil temp" Yet it looks like the second two modes are both Boost and AFR. Does that sound right? |
06-30-2011, 04:30 PM | #5 |
Rep 7,377
if you look at the procede software screen you will see what all gauges modes do.
06-30-2011, 04:32 PM | #6 | |
1743
Rep 17,960
Drives: A Lot
The gauge modes are explained, in chart format, in the software. There is a mode for Boost+Oil temp as well as a mode for Boost+AFR. Shiv |
06-30-2011, 04:36 PM | #7 | |
Rep 1,035
Car has 69K so I will pull out the outlet VANOS and give it a cleaning, this is the first time it popped up so i might as well give it a try, otherwise I'll order some new ones. |
06-30-2011, 04:39 PM | #8 | ||
1743
Rep 17,960
Drives: A Lot
1) Stock gauges 2) Boost+oil temp 3) Boost+AFR 4) Ign Advance+ IAT Quote:
06-30-2011, 04:49 PM | #9 |
74
Rep 1,543
That might jolly well be the case shiv, and while I do not want to get involved in a tuner debate, I personally feel that your tune, along with a whole list of others, is too aggressive to maintain daily reliability of non-upgraded key components. e.g: trans, HPFP, and turbos.
06-30-2011, 04:53 PM | #10 | |
Rep 1,035
Turkey k appreciate the input and you know I think you're threads (esp the AT trans ones) are awesome, but let's please keep on topic guys |
06-30-2011, 04:54 PM | #11 | |
1743
Rep 17,960
Drives: A Lot
Shiv |
06-30-2011, 04:55 PM | #12 | |
3441
Rep 79,211
FWIW my HPFP failed on my brand new bone stock car at 1200 miles. I dont know of any trans failures except 2 of the high HP guys (both auto well over 450WHP and TQ), and the Ive heard many stories of turbo failures on stock vehicles both locally and on the forums... |
06-30-2011, 04:56 PM | #13 |
Rep 1,035
I think it's pretty obvious that the only mode with oil temp is the stock one that doesnt show boost and ingore that horrible sound towards the end... text message! ha |
06-30-2011, 04:58 PM | #14 |
1743
Rep 17,960
Drives: A Lot
06-30-2011, 05:01 PM | #15 | |
Rep 1,035
The boost in park is obviously 0, if there was 0 gas i dont think my engine would be running. |
06-30-2011, 05:02 PM | #16 | |
74
Rep 1,543
There is a reason why the factory performance flash is no where near the type of power, you guys are pushing. |
06-30-2011, 05:05 PM | #17 | |
1743
Rep 17,960
Drives: A Lot
06-30-2011, 05:09 PM | #18 | |
Rep 1,035
We get how you feel buddy, and for the moment could we kindly shift back to the gauge questions. |
06-30-2011, 05:09 PM | #19 |
74
Rep 1,543
Jeff, a car is either overbuilt from the factory, or it is not. The 335I is a good example of a car thats soft, and not overbuilt. I still see tons of 90's DSMs, supras, 03 cobras, and eary WRX's with tripple digit miles, on insane boost levels. Anything over the factory performance tune, and you really have to beef up the turbos, and tranny. Even then you will still see all types of engine gremlins that seem to come with the N54.
06-30-2011, 05:10 PM | #20 | |
1743
Rep 17,960
Drives: A Lot
Shiv |
06-30-2011, 05:10 PM | #21 |
74
Rep 1,543
06-30-2011, 05:10 PM | #22 | |
Rep 1,035
Thanks for bringing this back on topic guys.
while i know this isnt "official" i took this from the user created V5 manual on google docs " Change gauge displays on the go Double tap the hazard light button quickly, gauges will be cycled through the following modes. Note: Mode 1 will be selected when advancing from mode 5, so the order would be 1,2,3,4,5,1,2,3,4,5,ect. " |
