Reviews for xi coilovers
07-01-2011, 05:25 PM | #1 |
Rep 788
Either getting the kw v1 or h&r coilover for xi. The h&r has a lower drop in front from what I read (2.5in vs 1.8in). I just wanna make sure they close up that front rake/gap the xi's have. H&R seems to be enough of a drop but what about kw?? How u guys like them ??? Any reviews??
JB4 Trebila tuned cp-e IC AMS exhaust BMS DCI AR DP's METH RB TURBO
19" VMR VB3 Stoptech BBK TC KLINE VORSHLAG SPEC STG 3 OSS design Last edited by Chrisred; 07-01-2011 at 05:30 PM.. |
07-01-2011, 05:35 PM | #2 |
Rep 225
Drives: E92 335xi
e92 335xi Black Sapphire Metallic - Saddle Brown
| JB4 | WW Meth | BMS DCI | Eisenmann Race Quad | AR Catless DPs | KW v1 | LUX v3 | Aero Lip | Painted Reflectors | Matte Black Grill | OEM 230s | CF CSL Trunk | |
07-01-2011, 05:54 PM | #3 |
Rep 93
KW since you live in Montreal and will benefit from the stainless steel body. Don't wanna have to worry about coping with the elements. I just picked up a set from a forum vendor for the same reasons you did; eliminate front rake and needed something good in snow/salt season.
07-01-2011, 06:25 PM | #4 |
Rep 225
Drives: E92 335xi
v1 - stainless steel front only.
v3 - stainless steel front AND rear.
07-02-2011, 06:01 AM | #6 |
Racer 5
48
Rep 823
Drives: '09 E92 335i xDrive M Sport
The KW V3 isn't in your comparison but the pics in my sig will give you a point of reference.
07-02-2011, 04:24 PM | #7 |
Loading...
342
Rep 2,187
Drives: 91' E30 318is
I have H&R coilovers and the performance is great. I'm not worried about corrosion... I live in a desert (which isn't a bad thing). But since you live in Canada, go with KW's. I don't know how much I would trust a spray to avoid corrosion over a long time.
07-04-2011, 11:13 AM | #8 |
Waaka Waaka
41
Rep 486
Hey, that's my link above
After raising the coils a 1/2 inch just 2 days after that pic was taken, due to scraping in my poorly designed underground (nice to have this flexibility), I still can't say enough good things about the increased handling and looks. I was skeptical about spending $1700 or so but well worth it. It really is a must have if you enjoy on ramps. |
07-10-2011, 03:16 AM | #9 |
Rep 534
I have the KWV1's and I can honestly say that I'm still really happy with them. They held up through one of our worst conditions this past winter. The ride quality is so close to stock that I often forget I have coilovers installed. Here is a pic of my setup. With before and after.
Before: After: |
10-31-2011, 01:01 PM | #10 | |
Rep 125
can you share the list of support mods that you needed besides the KW V1 kit? like camber kit, any accessories, etc? Also, how easy is it to adjust the height on the unit? did you try out the H&R coilovers before getting the KW? thx. |
10-31-2011, 01:06 PM | #11 |
290
Rep 28,154
i don't think you will be happy trying to adjust the h & r's after being installed for a winter, they use steel threaded adjusting collars in the rear, and the threaded section hangs down below the lower control arm, so they will be in direct line of fire for snow, salt, ect. i'd go with kw's, they use aluminum adjusters for the rear, and they are above the spring, instead of below like the h & r
10-31-2011, 01:14 PM | #12 | |
Rep 5,417
11-25-2011, 11:58 PM | #14 | |
Snow Wizard
35
Rep 425
I love the look of it. I would also appreciate the opportunity to take a ride, or speak with you to find out the differences with the KW V1's. Looks like you are in Alberta?? |
11-26-2011, 09:56 AM | #15 |
15
Rep 361
Drives: '09 M3 AW Carbon roof DCT '11
Just to add another look..
Before and after, 335ix with H&R coilovers, modest drop. 18" wheels on both, 235 - 265 non-RFT on drop. The ride is great and a big difference in handling. Great value.
2009 M3 Alpine, carbon roof, Akra slip on.
2011 335ix, Le mans Blue, Black Dakota, M-sport, PE Exhaust, VMR VB3's, ZCP 359m's, JB Stage-2, H&R Coilovers. Last edited by Ctm309; 11-26-2011 at 10:01 AM.. |
11-26-2011, 10:15 AM | #16 |
Rep 1,188
Drives: 2008 e92 335xi
