The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d experimenting new mods
      07-13-2011, 09:44 PM   #1
335dM
Drives: 335d m package
well i just installed my JBD today (set at 80%) and will be experimenting water injection( would like a kit with an electro-magnetic pump like Aquamist use to have) and adding a better aftermarket front mount intercooler and piping.
any suggestion would be appreciated since i dont know yet if 335i i/c would fit with little mod.
I have looked into 2 brand of water injection kit : cooling mist or Aquamist
My goal is to hit 400hp from my diesel engine while keeping a strong reliability by only cooling intake charges and better flowing
      07-13-2011, 09:50 PM   #2
taibanl
taibanl's Avatar
281
Drives: BMW
Do you think the stock engine does not generate enough compression?
      07-13-2011, 09:59 PM   #3
335dM
i just want to try to lower intake temp as much as i can and trying to burn better diesel for also better fuel economy. As i stated, i'm experimenting
      07-13-2011, 10:05 PM   #4
335dM
water injection will allow higher boost pressures being run without detonation and high pressures.....increases torque. It’s all about torque
      07-14-2011, 08:29 AM   #5
f00dstamps
Drives: 2010 BMW 335d
Do you think our transmission can handle more torque than a JBD @ 100% (this is what I have mine set at) plus other mods?
      07-14-2011, 03:26 PM   #6
Insider
Insider's Avatar
14
Drives: 2007 335i
I could be wrong, but I don't think anyone has hit 400hp on the diesel. You are going to need the gas version for that.
http://www.insiderpicks.com - The world's best stock picks.
      07-14-2011, 06:53 PM   #7
335dM
Of course it is possible ! Just not done yet!
      07-14-2011, 06:56 PM   #8
335dM
The transmission is design to take over 540lbs of torque ! If u take good care of her without brake boost... Everything should be fine. This tranny if I'm correct comes from a v8 or v12 I don't remember to support higher torque numbers
      07-14-2011, 06:57 PM   #9
335dM
BMW 335d uses only 60% of it's potential )
      07-14-2011, 07:28 PM   #10
taibanl
taibanl's Avatar
281
Drives: BMW
Uh. Im pretty sure JBD @ 100% is within a single digit (ft-lbs) of the tranny torque limit. Good luck!
      07-14-2011, 09:13 PM   #11
335dM
540 lbs is not the limit! It's a number that the tranny can hold before having a risk of failure! We are far from a tranny break down on the "D"
      07-14-2011, 09:16 PM   #12
taibanl
taibanl's Avatar
281
Drives: BMW
..To each his own...
      07-15-2011, 08:27 AM   #13
DieselDiner
DieselDiner's Avatar
486
Drives: 335d
Our cars have the ZF 6HP28 transmission, which is rated at 700Nm, or 516 ft/lbs. of torque. So we do have some room to go upwards from the factory rating of 425 ft./lbs., but do be careful!
      07-15-2011, 02:14 PM   #14
Concentric190
Drives: 335d
1997 BMW M3  [0.00]
2009 BMW 335d  [0.00]
1995 BMW M3  [0.00]
interested to see how far the D can be pushed
///Andres
09 335d evolve tuned - 327whp / 490wtq -- 13.0@105
95 M3 Turbo - Built 3.0l s52, PTE74GTQ, AEM EMS & CDI
97 M3 NASA TTB build for 2014!
      07-16-2011, 01:43 AM   #15
ChiDiddy
50
ChiDiddy's Avatar
19
Drives: pop smoke
Dont think you see close to 400hp with w/m injection, FIC, and JBD...
need exhaust upgrades, further tuning, etc
      07-16-2011, 03:25 PM   #16
335dM
U are propably right but I will try anyway and only dyno's will tell
      08-05-2011, 12:50 PM   #17
Thud
Throbbing Member
43
Drives:
Or propane.
2014 Tesla Model S 85kwh
Previous cars:
2011 335d / Deep Sea Blue / Saddle brown / sport / premium
2008 BMW 135i / 6MT
2002 Z06 Corvette
      08-15-2011, 07:40 PM   #18
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2021 M5 Competition  [0.00]
2016 BMW 550i  [0.00]
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Originally Posted by Thud View Post
Or propane.
This is what I'd like to do...
      09-21-2011, 01:44 AM   #19
Auto
Sweden
171
Drives: MB CLS 63 AMG
400hp/835nm+ has been done in Sweden!
http://dcsforum.se/dieselsnack/viewtopic.php?f=4&t=6238
http://www.garaget.org/?car=223177
      09-21-2011, 08:03 AM   #20
Concentric190
Drives: 335d
1997 BMW M3  [0.00]
1995 BMW M3  [0.00]
Sweden is always again of the F/I game.
///Andres
      09-21-2011, 08:44 AM   #21
DieselDiner
486
Drives: 335d
Originally Posted by Auto View Post
Amazing. Not sure I would want to drop that much power on our tranny.
      09-21-2011, 12:18 PM   #22
hotrod2448
grand poobah
hotrod2448's Avatar
Drives: F80 M3, F10 535i
2011 335d  [0.00]
Swedish doesn't translate with google very well.
Jahapp here, new gas project be set up
starting with a little half bad pictures better, What should be done one Folders 2 built downpipe and full-flow exhaust system, three possible flow preppa turbo eggs 4 ev preppa aut 5 My goal is Sweden's best 335d Coupe 2011
Where does one find these "turbo eggs"?
