DIY Poor Man's Piano Black Trim.
04-17-2007, 03:23 PM | #1 |
Rep 51
Drives: 2006 BMW 330xi
This is something i took on and decided to do myself since it wasnt that expensive. I purchased a damaged wood trim kit on ebay i was going to have it professionally taken care of until i got bored. This is what i did:
1) Sanded down all the gloss on the complete set of the trim this includes -left dashboard -right dash board -center console -ashtray cover -passenger side front trim -passenger side rear trim -driver side front trim -driver side rear trim 2) after all were sanded and cleaned from dust I primered with Rust-oleum sandable primer. 3) when everything was dry I prepared for painting by lightly sanding with 320 grit paper to assure that the surfaces were clean and smooth... this assures no specs and bubbles or what not. 4) This is the kicker... i have seen many people immitate the Piano Black look with metalic black or deep black but Piano black is basically lacquer black. So i went down to the ol' Home Depot and picked up some Rust-oleum Project Specific black lacquer spray paint. Gave every piece a good two coats and sure enough the surface was smooth and deep shinny black. ***** Note: Be very patient with the coats do not paint over wet layers because it wont look smooth. this paint was tricky and with black you can see every imperfection. PATIENCE!!! ***** The end result looks good but i am yet to install it since it has been raining in New Jersey for like 900 hours. I will post pics later when the sun comes out.
2006 BMW 330xi/Alpine on Terra/I-Drive/Sport Pack/Premium Pack/Cold Pack/Comfort Access/Blacklines/30% Tints/Carbon Emblems/ACS Roof Spoiler/OEM Deck Spoiler/ACS Lip Spoiler/Mattig Eyelids/Piano Black trim/smoked side markers. |
04-17-2007, 03:52 PM | #2 |
Rep 2,134
Great initiative. Love to see what you did.
2007 E92 335i Coupe: Monaco Blue/Premium/Sports/Winter Package/Nav/CA/6MT/TT/Active Cruise/Active Steering/iPod/Rear Shade/Tint/Short Shifter/OEM Alum Pedals//
04-17-2007, 07:19 PM | #4 |
Rep 2,816
04-17-2007, 07:47 PM | #6 |
Rep 6,750
I'd be curious to see how this holds up against things that could scratch the surface. I always thought plastic surfaces were supposed to be prepped with adhesion promoter.
04-17-2007, 08:10 PM | #7 |
Rep 6,664
Clear coat for the deep look.. And protection... I'd give it two or three coats of clear IMO..
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. |
04-18-2007, 09:25 AM | #11 |
Torque junky
115
Rep 1,688
Drives: Remapped e90 330d
Looking forward to seeing this! I can't believe you managed to get a piano finish yourself (but kudos to you if you did )
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
04-18-2007, 10:56 AM | #12 |
Rep 5,842
Drives: 2006 325xi
cant wait to see how it looks.
Ever think of painting it the perlscant chrome like the the way tot door handles are? |
04-18-2007, 11:14 AM | #13 |
Rep 4,558
I have to see how this looks. Can't wait for the pics.
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i |
04-18-2007, 06:07 PM | #15 |
Rep 4,558
You mentioned you used 320 grit after you primed.
What grit did you use to get the factory clear coat off? Did you also sand in between coats of the black?
04-18-2007, 06:33 PM | #16 |
Rep 2,221
interesting.... pics please!
04-19-2007, 12:02 PM | #17 |
Rep 51
i wet sanded between coats. i sanded the primer i sanded the two coats of black then the last coat of black i didnt. TOday im putting on the clear.
04-19-2007, 12:10 PM | #18 |
Rep 198
Did you use tack cloths after sanding? If not, get some. They will pull off all of the little tiny bits of sanding dust that you can't get off any other way...you'll thank me when you're not seeing garbage in the clear coats.
04-19-2007, 12:30 PM | #19 |
Rep 51
i hate specs and bubbles. I have sanded more than i have painted.
04-19-2007, 12:50 PM | #20 |
Rep 4,558
Can you post some close up pics before you put them in the car? I think I may want to try this mod. If I do I am going to try with a small piece of trim first to see how well I can do it. Less I have to replace if I screw up.
04-19-2007, 12:54 PM | #22 |
秘書負責保持它真正
353
Rep 24,954
ummm i think if you screw up one piece, you have to buy the entire trim set. I don't think they sell individually ... i could be wrong
