08-06-2011, 09:31 PM | #1 |
Rep 2,898
Charge Pipe: Lousy Design
Just back from first day on track with my 1M.
Took it easy first session learning the car, but began pushing second session. Coming onto the bridge straight (at Summit Point's Shenandoah Circuit), "pop." Reduced power and check engine light. Immediately suspected the charge pipe, and -- after getting back into paddock -- I checked. Sure enough, charge pipe had come off throttle body. 10 minutes later, it is back together (with the circlip loudly snapping into place). Go back out next session, and in exact same place, "pop" (again). Same deal. Was able to repair it in 5 minutes this time. I'm aware of several other 1Ms that have had this problem and figure that this will be (or is) a common problem with 1Ms that are tracked. Perhaps the overboost feature and the stresses of track use puts a marginal design over the edge. Neil |
08-06-2011, 09:50 PM | #3 | |
Rep 2,898
Also spent some time on the skidpad and car was a hoot. Other than charge pipe (about which BMW and its Motorsport division should be embarrassed), I'm very pleased. Neil |
08-07-2011, 09:12 AM | #6 |
Rep 2,898
08-07-2011, 09:14 AM | #7 |
Rep 2,898
08-07-2011, 10:34 AM | #8 |
66
Rep 306
Can someone post a pic of what this charge pipe looks like and where it comes off at. This would be great so i know what to fix once i get mine.
Thanks. |
08-07-2011, 11:02 AM | #9 |
Rep 2,898
Look at part no. 5 (charge air induction tract):
http://www.realoem.com/bmw/showparts...85&hg=13&fg=20 It connects to the throttle body attached to the intake manifold. Neil |
08-07-2011, 01:30 PM | #11 |
223
Rep 1,565
Make sure that the clip is properly seated. The clip positively locks the hose in place and it would be very difficult to get the hose to slide past the metal clip.
What is the overboost psi on these cars? |
08-07-2011, 02:21 PM | #13 | |
Supreme Allied Commander
3837
Rep 54,338
Drives: F80 M3
08-07-2011, 03:14 PM | #14 | |
142
Rep 1,700
08-07-2011, 03:26 PM | #15 |
Rep 740
this is definately not a 1M problem because it happened to me multiple times until i went aftermarket and i havent had any problems since
LMB 135i: Gone
AW 1M: Current #211 of 220 |
08-07-2011, 04:12 PM | #16 | |
Rep 2,898
I'm convinced that a bit more camber would go a long way. Neil |
08-07-2011, 04:25 PM | #17 |
11
Rep 323
good to hear she runs well out of the box on Shenandoah...it is a pretty technical track without much runoff. any video? if not could you post some more impressions on specific areas and the track and front/back straightaway speeds I'd appreciate it.
08-07-2011, 04:26 PM | #18 |
Rep 475
Drives: 1///M Coupe & ///M2 CS DKG
there are many probléme in France too
a friend has his charge pipe who have explosed after two lap tour on a track!!! BMW must react!!!
- Série 1 ///M BSM - |
08-11-2011, 10:56 PM | #19 |
ON TRACK !
12
Rep 86
This is the exact problem that I report maybe 3week ago ! The only way is to change it .
There is what happen Actualy I was looking to change it for the active autowerk.
060 / 220 CA || BMW 1 series M Coupé || Alpine White||
MODZ:BMW Performance Steering, Matte Black Kidnney Grill, Vishnu Pro-ceed, Matte Black ///M Badge, Tinted Windows, Black Side Marker with Clear Tint. AFE Intake, ActiveAutowerke Downpipe, ActiveAutowerke Charge pipe With BOV kit, Black Exhaust tip, PowderCoated Wheels|| |
08-21-2011, 09:12 PM | #20 |
Stay Ripping
60
Rep 546
I just got back from my first track outing with the 1m. My chargepipe actually broke, not just popped off the throttle body. In the market for a solution.
THE GOBBLER- S.O.H
08-22-2011, 09:21 PM | #21 | |
Rep 2,898
Neil Last edited by MDORPHN; 08-23-2011 at 08:07 AM.. |
08-22-2011, 09:52 PM | #22 |
They like my Swag...
433
Rep 3,762
Drives: 15 GSM 435i GC
That's crazy! I don't know why that happens to you guys and not to us non-m guys. I'm sure that we have been running higher boost!?
Perhaps the way the overboost comes on? Too abruptly?
2015 435i Gran Coupe - Current 2008 AW 135i - Sold |
