09-04-2011, 12:54 PM | #2 |
Rep 1,447
09-04-2011, 02:03 PM | #3 |
Rep 1,421
351 rwhp (dynojet) indicated 186 mph on GPS. The rev limiter was very close but "the driver" didn't hit it in 6th. This was with a tail wind.
Dan Parker
09-04-2011, 02:17 PM | #4 |
Rep 113
09-05-2011, 12:01 PM | #8 |
Rep 113
Can not believe that the 1M runs 186 mph.
Maybe with 10% slope and a strong tail wind. The Aerodynamics is bad and not suitable for top speed. CW value is 0.35. With 350rwhp it´s real 177mph by 6300rpm I have no tune. What´s the V-Max open without tune? Think 169mph. What do you think? |
09-05-2011, 12:17 PM | #9 |
European Editor
10532
Rep 22,992
I think a 1M with tune will do about the same V-max as a 135i with a tune.
I know with my 135i (I have a flash tune 380 PS and 520Nm of Tq and an open V-max) that I have seen 274 kph with my Navi (TomTom), that was in 6th at 6,100 rpms. I also know... quite a few tiimes I have seen 6,300 rpms - but with no Navi. I think that is 177 mph (287 kph) real speed. Not what shows on the speedo! Speedos read higher than true vehicle speed. My car still felt like there was more speed left in her. Btw... I have PS3's 225's and 255 tires on stock wheels. Most of the 1erforum.de guys say a tuned 135i should do around 294 kph (actual speed). You only need the right (empty) autobahn and enough of a lead foot to do it. The one series is NOT the best high speed car I have driven. It makes for a bumpy skippy ride at anything over 140 mph. A stock 1M is limited to 255 kph. Some 1M guys have said they have seen 274 kph... but IF you figgure in that the speedo read 5% high... that is really a 260 kph speed. Ad M has said no higher V-max chip for the 1M like they offer for other M models to go up to a real 280 kph V-Max. I think its because of the jumpy handling of the one series. |
09-05-2011, 12:29 PM | #10 |
Rep 1,421
http://androidheadlines.com/2010/05/...pp-review.html
This is what the driver used. Windows up, no A/C, and a very good road with nearly a 3 mile straight. Before the straight he hit around 110 and then let it go starting in 4th gear.
Dan Parker
09-05-2011, 12:38 PM | #11 |
132
Rep 1,898
09-05-2011, 12:52 PM | #12 |
European Editor
10532
Rep 22,992
09-05-2011, 01:29 PM | #13 |
Rep 1,421
Worse aero meaning the front end? Between the air curtains blasting turbulent air out of the wheel wells (reducing front end lift) and the larger openings for the oil coolers and intercooler I doubt there is any significant difference.
Dan Parker
09-05-2011, 06:18 PM | #16 |
Gold Member
161
Rep 512
