Heading to the drag strip
09-06-2011, 02:25 PM | #1 |
Rep 241
Heading to the strip for the first time on thursday and have some questions. I have an 07 335i with dci intakes and JB+. Should I run some race gas in it? if so what grade and how much? From reading on here it sounds like brake boosting to about 2k and then getting on it is the best way to launch, is this correct? Also, what are the chances of hitting 12's with this setup? thanks for the help guys!
09-23-2011, 08:18 AM | #3 |
Rep 190
Re
Id just run 93 in this case. Unless you have it turned to 100%, in that case 100 octane mix may help. DCI doesn't really help unless you start boosting 15 psi+. However, you may be able to hit 13.1 if you can hook up. Drop psi to 20 in rear. Let us know what you ran!
09-23-2011, 08:47 AM | #4 | |
Rep 241
09-23-2011, 09:00 AM | #5 |
Rep 190
Cool, I'm going tonight if rain holds off. Orlando Speed world. I have JB4 and DCI. RFT.... I'm going to run 100oct, map 2 and 7. Last time I did 1.9 60 ft, hopefully I can replicate tonight
