BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - New England > Helmets
      04-25-2007, 02:16 PM   #1
Titania
Drives: 2007 328 xiT
Helmets
For those of you that autocross or do track events, where did you get your helmets? Is there some place local that sells autocross/racing supplies?
      04-25-2007, 02:21 PM   #2
Dleo
Dleo's Avatar
Cyprus
210
Drives: 2010 X5
I would think any motorcycle helmet would work, those are the ones i usually use. You can pick them up at any motorcycle shop, dealership, cycle accessory store, etc..
      04-25-2007, 02:31 PM   #3
Titania
I should have stated that I was looking to pick up an SA helmet, just to cover my bases. If I can't find one, I may end up just getting a motorcycle helmet.
      04-25-2007, 02:37 PM   #4
Dleo
Dleo's Avatar
Cyprus
210
Drives: 2010 X5
is that what is required for the course? I have not been to a course that required SA helmets, just usally use my motorcycle helmet, must be a great course.
You can always buy online if you know your size:
http://www.discoveryparts.com/cgi-bi...FRzmgAodCCAFaQ
      04-25-2007, 02:59 PM   #5
Titania
BMWCCA only requires M helmets. But, IIRC, some SCCA events require SA helmets.
I don't know my size is the problem. I've never worn a motorcycle helmet before, and when I've done autocross in the past, I always shared one of the club helmets.
Thanks for that link. They're cheaper than the other online place I was looking.
      04-25-2007, 03:05 PM   #6
Dleo
Dleo's Avatar
Cyprus
210
Drives: 2010 X5
you might want to go to a local motorcycle shop and try on a few helmets, just so you get an idea of what size you might need, GL
      04-26-2007, 12:50 AM   #7
vs60r
Drives: 335i
If you are into road course racing, then definitely get a SA helmet. Don't just settle for a M.
Dleo's idea is good, try the M helmets at a motocycle place, that will give you the size reference to purchase a SA helmet.
      04-26-2007, 06:36 AM   #8
Titania
Thanks for all the advice. I appreciate it.
If nothing else, trying on the motorcycle helmets should tell me if there are certain companies' helmets that just don't fit right, and I should stay away from.
