XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Vendors Classifieds
      09-20-2011, 11:27 AM   #1
ar design III
ar design III's Avatar
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
ar design: ESS S63 Direct Flash Software
The ESS X5M/X6M DirectFlash Performance ECU software is a result of extensive testing and exact calibration of ECU parameters to allow considerable performance gains on an otherwise stock car. The ESS S63 performance software is developed and tested in extreme heat in the Arizona desert as well as extreme cold temperatures in Scandinavia. Typical peak gains are in the 40-50whp range. Catless exhaust option available upon request.
When ordering this product you will receive 1 ESS DirectFlash handheld programmer which will VIN lock to your car. This unit can be used to program between stock and tuned, and it can also be used to load custom files/race fuel files/updates received from ESS over email. The ESS DirectFlash unit can hold up to 10 tunes + stock, allowing the end user full control over what program they want to run.
Part number: 101-100
Top Speed Governor: Removed
RPM Limit: 7000RPM
Fuel requirement: 91US/95Euro
Horsepower (peak): 590 DIN (Stock 555)
Torque: 790NM (Stock 680NM)
*Correction factor for drivetrain loss is 15% above RWHP as seen in dynograph (RWHP/0.85)
Application intended for: All X5M, X6M.
Purchase Here!
Save 10% When Paired With Our 3" Hi-Flow Downpipes!
      09-30-2011, 11:27 AM   #2
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
      10-03-2011, 10:41 AM   #3
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Monday Bump!
      10-24-2011, 11:01 AM   #4
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
      11-02-2011, 12:00 PM   #5
ar design
ar design's Avatar
Drives: 04 M3
Bump for the best flash available!
-Critter
      10-25-2012, 10:32 AM   #6
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
      11-01-2012, 11:37 AM   #7
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
      11-08-2012, 10:54 AM   #8
ar design
ar design's Avatar
Drives: 04 M3
-Critter
      11-15-2012, 12:24 PM   #9
ar design II
ar design II's Avatar
Drives: which one?
Up!
      12-18-2012, 10:31 AM   #10
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
      01-02-2013, 10:41 AM   #11
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
      07-19-2013, 03:08 PM   #12
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Friday Bump!
      08-08-2013, 11:43 AM   #13
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
      08-14-2013, 12:33 PM   #14
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bueller... Bueller... Bueller...
      08-16-2013, 11:26 AM   #15
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
      09-12-2013, 12:44 PM   #16
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
      09-18-2013, 05:59 PM   #17
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
      09-23-2013, 11:42 AM   #18
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
To The Top!
      10-03-2013, 11:43 AM   #19
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
      10-04-2013, 08:40 AM   #20
SouthShoreM3
Passes everything but the gas station
Drives: 2010 E90 M3
To AR...your DP with cats do you know if it is emissions compliant with regards to passin OBD readiness?
      10-08-2013, 11:30 AM   #21
ar design III
35
Drives: M3
'01 M3  [10.00]
95 M3 Turbo  [9.00]
Bump!
