Steptronic as a Manual
09-22-2011, 05:52 PM | #1 |
Rep 112
I'm loving my new d! The only thing is getting used to an auto transmission. Its a first for me. I even keep stepping where the clutch would be out of habit!
1.) I'm driving it in sport mode only. Shifting manually with the "stick" and/or paddle shifters. Just as I would my MT. I'm also downshifting as I would in an MT. Is this an issue? It shifts so much in auto mode anyway. But only up. I read a few comments about this putting too much wear and tear on the transmission vs brakes. Is an auto designed for downshifting for slowing down? 2.) The car automatically goes to M2 when stopped. Why not M1? In Auto Mode, I assume it goes to M2 at a stop? So, should I just be launching in M2? Unless on a hill? 3.) Where do you normally shift and cruise at a constant speed? In sport auto mode it seems happy at 1900 rpm. I'll put it in auto to see, then back to sport to see the gear. Im always surprised how low the RPM is and how high the gear is. I'm such an auto noob! Thanks!
2011' 335d M Sport Space Gray/Chestnut/Glacier Everything but Washers
2008' 335i MT Monaco Blue/Black/Dark Burl Sport/Prem/Cold 2004' x3 3.0 MT Gray/Blk/Alum 2000' 328ci MT TIAG/Blk/Alum | 1986' 325es MT | 1981' 528i MT |
11-16-2011, 01:21 AM | #2 |
Rep 30
One glaring point I felt should be addressed is your question about whether an automatic transmission is 'designed for downshifting to slow down'.
The answer is NO, N-O transmission is designed to be USED to SLOW the car down! Some transmissions(those in vehicles that haul heavy loads) have trans brakes, but that's not what we're talking about here. YOUR BRAKES are the ONLY parts/system on your car, that is 'designed to be used to slow the car down'. If you use your manual trans to slow your car down, you're simply wearing out your expensive clutch-and possibly internal VERY EXPENSIVE transmission components, rather than the INEXPENSIVE and EASY TO REPLACE brake pads. If you use your Steptronic-type transmission to slow your car down, you're risking not only your internal gearing, but also your differential and ring and pinion. I guess people got the idea that using a manual trans to slow the car was a good idea from watching racing drivers back-shift as they're slowing. You'll also note that they also REV THE ENGINE to match the rpms on the back-shift. This action has absolutely NOTHING to do with slowing the car down. As a matter of fact, if the driver makes a mistake, and doesn't properly match the engine speed on the back-shift, he risks losing control of the car. When slowing down at high speed(s), most of the weight is on the front, thus VERY LITTLE weight is on the rear. If the driver does ANYTHING that aids in the rear tires losing traction(i.e. mis-matching the rpm's upon back-shifting, resulting in the rear tires spinning faster than the rpms can match-OR- USING THE TRANS TO SLOW THE CAR), the back end of the car will remove itself from the control of the driver, resulting in a plethora of possible problems, NONE OF WHICH the driver can do a whole lot about, since he's got to get the car slowed for the corner. His only real option is to let off on the brakes so some weight transfers off the front and onto the rear(and to also get the rears to speed up a little). Problem there is, again, he's got a corner to slow down for, so whichever way you slice it, he's screwed. Unfortunately I took the very long way of simply stating the fact that your BRAKES are what you use to slow the car down. Your TRANSMISSION is used to simply put the power down in the MOST controllable manner. Racing drivers DON'T use their transmissions to slow their cars down(well...at least when their brakes are working). People mistake them doing that, when in fact they're simply matching the engine speed with the wheel speed, in order to keep the chassis under control as he slips the trans into the proper gear to give him the best drive possible out of the next corner. I think I just typed my way through Tosh 2.0. I hate me! |
11-16-2011, 08:29 AM | #3 | |
Rep 80
Drives: 2011 335d Sport M-Sport
3) Fuel efficiency is the reasoning behind the bold I believe.
2011 335d M-Sport, Black Sapphire Metallic/Saddle Brown, Premium, Nav
Retired: 2010 335d, Monaco Blue with Oyster/Black, Sport, Premium, Nav, Comfort Access |
11-16-2011, 10:49 AM | #4 |
Rep 1,203
Drives: '11 STI, '90 325iS
From my understanding it launches in M2 due to the torque.
11-16-2011, 11:58 AM | #6 |
Rep 1,203
Clearly the 325 label was wrong
11-16-2011, 12:05 PM | #7 |
12
Rep 332
My 'd' is also my first automatic - ever. I must say I was surprised to observe
its downshifts as I braked for stop signs, etc. It was rev matching the vehi- cle speed for me. Even when I drove a manual, I didn't downshift while braking. I have not driven in sport mode as my goal is to minimize fuel consumption. even in regular mode - all that torque! |
11-22-2011, 12:54 PM | #8 |
Throbbing Member
43
Rep 1,433
Downshifting a diesel doesn't get you much in the way of engine braking anyway.
This car needs a jake brake.
2014 Tesla Model S 85kwh
Previous cars: 2011 335d / Deep Sea Blue / Saddle brown / sport / premium 2008 BMW 135i / 6MT 2002 Z06 Corvette |
