E90 LCI - ET35 Up front - Anyone running more aggressive lowered?
09-28-2011, 12:22 PM | #1 |
Rep 3,175
So I am running 19x8.5 et35 up front on a 225/35 series tire. I am lowered, fenders are not rolled, would prefer NOT to. No rubbing and the clearance in the wheel well seems tight esp when I crank the wheel the whole way, but again not rubbing. My wheel still seems a little tucked, just wondering if anyone is running a similar set-up with a more agressive off-set on a lowered car, w/no roll? If so, what specs and do you rub at all?
Thank you |
09-28-2011, 12:30 PM | #2 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
19x9 ET31 with 245/35. Lowered. No rub. Flush.
09-28-2011, 12:38 PM | #3 |
Rep 3,175
E90 right? Are your fenders rolled? Any modifications to the wheel well?
I just don't see how that could fit esp considering the tire size and wheel width! I can barely get my finger between the wheel well and my tire when I crank the wheel the whole way over. |
09-28-2011, 01:17 PM | #4 | |
Rep 8,003
09-28-2011, 01:22 PM | #5 |
Rep 8,003
Here are some more photos showing the front wheels in detail: http://www.e90post.com/forums/showthread.php?t=527634
09-28-2011, 01:46 PM | #6 | ||
Rep 3,175
09-28-2011, 02:15 PM | #7 |
BimmerPost Supporting Vendor
31
Rep 326
A 5mm spacer could work for you because of your tire size. We recommend a 235 for a 19x8.5 so since you're running a slightly narrower tire you could space the wheels out a tad.
09-28-2011, 02:19 PM | #8 |
Rep 8,003
That rubbing was with a bad alignment. The shop did not set the camber properly (they had one side set to -0.6 and one side set to -0.9). After going up to -1.0 for both, the rubbing went away.
09-28-2011, 03:04 PM | #9 |
Rep 3,175
Thanks Kevin, but now that you mention it, I think I am running a 235/35, sorry for the confusion. Do you still think that would be okay?
09-28-2011, 03:12 PM | #10 |
31
Rep 326
With a 5mm spacer you still might be able to pull it off. I can't guarantee it though since it isn't exactly our recommended fitment with the added spacer.
09-29-2011, 05:37 PM | #13 |
87
Rep 2,854
i may try 19x8.5 245 et23 once i do the m3 front control arm conversion. hopefully there will be enough camber
10-05-2011, 03:56 PM | #14 |
Rep 2,163
I'm currently running a 235/35 nitto nt555 19x8.5 et23 (with 10mm spacer) up front with no rubbing and lowered on the Eibach Pro Kit, OEM Performance Shocks and SP Perch. I'll post a close up pic later tonight.
10-05-2011, 04:46 PM | #16 |
Rep 3,175
I apprciated all of the replies and input. I am leaning towards trying the MS 5mm spacers sold by eas.
Depending how the fronts go may try 3mm spacers in the back running with a 265/30 series tire. |
10-10-2011, 11:40 AM | #19 |
Rep 3,175
Woudl love to see those pics! I am runnign the same wheel/tire size and suspension set-up and I just don't see how et23 would work unless your fenders were pulled/rolled.
10-10-2011, 11:55 AM | #20 | |
Rep 3,175
mrj25 found this post/pics of your car running et34 w/5mm spacers. guess this was before you up-sized your spacers. so you didn't get any rubbing on the fender liner when going over dips or when you cranked the front wheel as far as it would go?
10-10-2011, 03:11 PM | #21 | |
Rep 2,163
Front Front Passenger Passenger Side Front Driver Rear Last edited by mrj25; 10-10-2011 at 04:16 PM.. |
10-10-2011, 05:15 PM | #22 |
Rep 3,175
Thanks for the pics. So you say you are rolled in the back or was that a typo? If you're rolled I won't likely be able to fit 5mm in the back then since I am not rolled and I have no plans to roll. Maybe could get away with 3mm in the rear.
What brand spacer are you running? Any vibration issues at speed? BTW, your car looks great! |
