Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > fitment 101
      09-28-2011, 12:31 PM   #1
hdrewh
Drives: '09 E90
fitment 101
what exactly does "offset" mean, what does "ET" stand for, and how are these concepts used in making wheel decisions?
Thanks
<leaves apple on desk, takes seat, picks up pencil, opens notebook>
2009 E90 328i Montego Blue, Black Leather, 6MT, ZPP, Logic 7, HD radio, CA, fold-down seats, PDC. ED pickup 6/12/2009
mods: Koni FSDs, Eibach Pro's, Sport/Heated Seats, BMW Perf. short shifter, M-tech shift knob/e-brake handle/steering wheel, split armrest, black grilles, 50% tint, 3M clear bra.
      09-28-2011, 12:39 PM   #2
info@VMRWheels
BimmerPost Supporting Vendor
info@VMRWheels's Avatar
31
Drives: BMW
Offset is just the distance from the hub/back pad of the wheel from the center of the wheel. This of course is represented in millimeters, and depending on the offset it'll help you determine how far in or out a wheel will sit. Whenever you see an "ET" it's just how many millimeters it is. Here's what it really actually means.
Wheels are usually stamped with their offset using the German prefix "ET", meaning "Einpresstiefe" or, literally, "press depth".
The higher the offset, the more INTO the fenders the wheel will be. The lower the offset, the more OUT towards the fenders the wheel will be. So for instance if you have a 19x9.5 ET45 and 19x9.5 ET33, the ET33 version will be sticking out 12mm more than the ET45 (or as some may say, it will be 12mm more aggressive). When calculating wheel sizing you need to consider how much inner and outer clearance you have, what tire size you'd like to run, brand, model, etc. It will all depend on how you set up your car. Different cars require different width and offsets. Just remember that width differences will affect the outer and inner clearance. So even if the wheels have the same offset but different widths they will fit slightly differently. Hope that helps!
Here's a visual representation of what the offset of the wheel is.
[img]http://www.**********s.com/images/Products/Wheels/WheelOffset.jpg[/img]
      09-28-2011, 03:27 PM   #3
hdrewh
Drives: '09 E90
nice! thank you.
      09-28-2011, 04:07 PM   #4
info@VMRWheels
31
Drives: BMW
You're welcome!
      09-29-2011, 11:27 AM   #5
nekky
Wagon life
nekky's Avatar
39
Drives: '16 328d M Sport Touring
Perfect description. Good job
      09-29-2011, 12:27 PM   #6
info@VMRWheels
31
Drives: BMW
Thanks!
      09-29-2011, 12:29 PM   #7
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
Here is a visual of it :
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      09-29-2011, 01:47 PM   #8
drfrink24
Drives: 2008 335xi
Is there a chart of the minimum clearances (inside and outside, caliper, strut, etc..) for various e9x setups?
      09-29-2011, 01:52 PM   #9
info@VMRWheels
31
Drives: BMW
It really will vary on the wheel and the sizing it is offered in. Some wheels have better spoke clearance than others, some have better barrel clearance than others. Usually you could tell on fender/strut clearance easily. You can more or less measure how far the wheel is from your strut or from your fenders, but if you want to upgrade your brakes they usually have templates online that you cut out. You just fit these inside the wheels to make sure they will clear your components.
