2010 2011 BMW 5 Series Forum F10 Rim scratch repair some pics |
09-28-2011, 12:58 PM | #1 |
Rep 2,003
A small scratch on the rear rim, but made it through the clear coat.
Only sanded down the dirty clearcoat, did not sand through to metal. Recoat with clearcoat, re-sand and finish. You can see the damaged metal part through the smooth clearcoat. (Metal cannot be fixed unless re-machined totally, on machine face finish. Most rims are painted so would be different from this) |
09-29-2011, 01:38 AM | #2 |
Rep 2,791
Drives: F10 528i
You made a lot of effort grimmy. Not perfect but really admire your enthusiasm. Keep it up bro.
May I know what kind of clear coat you used?
2011 F10 528i Black Sapphire / Oyster Black 2000 E46 325ci Cabrio Titanium Silver / Black - retired 1997 E36/7 Z3 Montreal Blue / Black - retired |
10-02-2011, 12:49 PM | #3 |
Rep 2,003
It's the 2-1 mix i got with the ebay paint kit .. scratchdoctor ..not bad, better than the one from same place that come with rim repair kit. post some pics later when have chance..
10-03-2011, 03:22 AM | #4 | |
Rep 1,198
my rims are cratch too by my dad and I just can not be othered to repaire it cos I know it will happen again. |
10-03-2011, 12:09 PM | #5 | |
Rep 2,003
scratch doctor body paint match was too dark for me, paintscratch .com was good match.. these small repairs are totally not worth the time .. just fun to try to see if u can do it |
10-04-2011, 12:18 AM | #6 | |
Rep 418
2011 F10 535i Sophisto Grey/Oyster, ACS spring, Forged 1, Michelin PSS, Eisemann Quad-Exhaust,
2013 991 Carrera S PDK, Aqua Blue/Beige, PSE, PDCC, Sport Chrono Package, Paddle Shift Steering Wheel, PDLS--delivery in July2013 |
10-04-2011, 12:53 AM | #7 |
Rep 2,003
10-12-2011, 07:31 PM | #9 |
Rep 2,340
Drives: 650GC/E93M3/Lexus LS600HL
Answer is YOUR Eibach 550 springs
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT 2011 F10 550i M Sport - Retired |
10-12-2011, 10:46 PM | #10 |
Rep 2,791
Drives: F10 528i
Another fascinating project for you grimmy. Not easy, need to do a lot of things.
10-13-2011, 11:54 AM | #12 | |
Rep 2,003
Besides KW, there is also Bilstein shock for f10 .. it says paired with eibach, dun know how it would be like paired with HR, but another alternative, cost 9-10k.. I start to think improve the shock will improve the just springs, coilover advantage is both are paired/tested to work well together.. so if u match yourself trial and error /luck.. |
10-13-2011, 12:59 PM | #13 |
Rep 2,003
http://www.aze-tuning.de/gutachten/E10-20-022-01-22.pdf
Difference between eibach 523/8 and 550, is 13.25 vs 13.5 mm wire diameter and length 318 vs 334mm length (front), same width for back 12.5mm, length 327 vs 332. So 16mm longer (untensioned) and 0.25mm thicker on front, on back 5mm longer. Hopefully this will result in higher ride height by at least 13mm (tensioned), as well as less dip under additional weight (cornering) Calculated drop from OE is 17mm F, 26mm R = slightly more than 'M' drop on front, nearly eibach drop on rear |
10-14-2011, 01:35 AM | #14 |
Rep 2,791
Drives: F10 528i
Bilstein is quite hard core. Don't want to be a guinea pig. May be you can try first grimmy. You are always the pioneer.
10-14-2011, 02:45 AM | #15 |
Rep 1,198
10-19-2011, 10:42 AM | #17 |
Rep 2,003
So I measured the ground-to-fender height twice, with min. gas and with full gas:
low: FR FL RR RL 71.5 72.1 71.5 71.7 full 71.7 72.2 70.8 71.3 So 60L gas (=60kg) decreases rake (front-back bias) by raising front ~1.5mm and lowering back ~5.5mm Can't help to think car is set up perfectly for LHD (for only driver).. too bad ours is RHD Will need to measure the springs when removed from car, to see if the difference comes from there. If so, the problem is known, if not, will have to consider 5mm-10mm pads.. will need to research which materials best. Eibach Springs L/R are deviating by 2mm untensioned (may be different under tension) Final goal is L/R level with no driver, or up to +5mm raised in FR(driver) |
