2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2012 BMW 528i Turbo 4-Cylinder First Drive Review by Insideline
      10-01-2011, 01:12 AM   #1
-=Hot|Ice=-
Been There, Done That.
-=Hot|Ice=-'s Avatar
Drives: 2013 BMW M3
BIMMERPOST
     Featured on BIMMERPOST.com
Originally Posted by InsideLine
Name:  Screen Shot 2011-10-06 at 12.11.40 PM.jpg
2012 BMW 528i First Drive
More With Less
Many years and generations ago, the 528i was the turbine-smooth, six-cylinder pinnacle of the 5 Series range. This engine capacity first appeared late in the life of the original 5 Series in 1979, last appeared two generations ago and reemerges today as the entry model of the current 5 Series lineup. But not as a 2.8-liter, nor even a six-cylinder.
The 2012 BMW 528i engine is now a 2.0-liter turbocharged four-cylinder. The mill even looks downsized when you open the hood, a sizable void yawning between the nose of the engine and its radiator, yet it generates a promising 240 horsepower — identical to that of the outgoing 2011 six-cylinder 528i, but boasting an extra 30 pound-feet of torque. And, thankfully, 0.4-second-quicker sprint to 62 mph (6.3 seconds).
Economy and emissions gains are the main goal of the displacement and cylinder reduction. The 2012 528i improves on the 2011 model's fuel economy by 1 mpg city and 2 mpg highway and achieves an EPA rating of 23 city/34 highway mpg. The improvement is aided by a new stop-start system integrated into the standard eight-speed automatic transmission. But the key to this new engine's fuel-sipping strength is a single twin-scroll turbocharger that functions in concert with a number of well-established BMW technologies.
These include double VANOS variable valve timing and the company's Valvetronic induction system, which does away with the throttle plate. The 528i's four-cylinder routes exhaust gases from each pair of cylinders to a separate turbine inlet to speed the engine's reaction to a twitching right foot. Fuel is fed by precisely metered, solenoid-controlled direct injectors, while refinements to the Valvetronic system have also improved its precision.
Torque From Low Revs
The result is a very impressive 240 hp from 2.0 liters and even more usefully, a stout 258 lb-ft of torque from as low as 1,250 rpm. This torque stream is sustained all the way to 4,800 rpm, promising the kind of midrange punch that normally aspirated six-cylinder gas engines rarely offer. And you can feel its effects almost as soon as you move off, the 2012 BMW 528i advancing with a confident authority that's heightened by the tremor-free activities of its eight-speed automatic transmission.
All those ratios help disguise the steep ramp to the torque peak, which kicks in with authority as the revs approach 2,000 rpm. But to uncover this, you must switch to manual shifting so you can hold the car in a gear, trickle it down to 1,000 rpm in 2nd and stomp on the accelerator as if you hate it. There's a brief pause, followed by an excitingly exponential surge that leaves no doubt that this is a rapid car. By 2,000 rpm it's pulling like a lashed mule and there's a substantial power spike at 3,500 rpm. The acceleration is unrelenting until 6,500 rpm, when the transmission automatically upshifts to let you do it all over again.
It offers an unusual breadth of personality, ranging from comfortable econo-sedan to sporting four-door.
Though this four has lost the turbinelike wail of the six, it's more powerful and it stays smoothly unfussed until it closes on 6,600 rpm. The culture of the six is gone, but there's more honest muscle to this engine. Those familiar with a BMW straight-6's smooth-spinning ways will miss it some, but it makes the 5 Series a better car. There's some refinement missing, but the return of lighter fuel bills, more torque and extra entertainment is a worthy trade.
Control Your Driving Experience
Further entertainment can be had from the new rocker switch occupying the center console near your right knee. Grandly labelled the "Driving Experience Control," it alters the throttle response, steering weight, stability control thresholds, transmission shift strategy and the calibration of the dynamic dampers, which come with both the M Sport and Sport option packages.
There are four settings, labelled "Sport+," "Sport," "Comfort" and "Eco Pro." Driving Experience Control is most worthwhile if you ordered those dynamic dampers, whose settings alter the character of the car noticeably from the pillowy comfort of a big, old Buick — though without the wallow — to sensations distinctly more athletic when you aim the 528 at a bend and hard-charge it. As you'd hope of a car promoted as a sport sedan, it spears them with a satisfyingly quiet confidence that's sharpened by the fact that the four-cylinder engine in its nose is lighter than the outgoing six.
Select the Sport+ mode, which relaxes the stability control system's interventionist policy and you can indulge the occasional tail slide. But it's the smooth and rapid fluency down the road that characterizes this car more so than exploring the outer reaches of its rear tires' grip. The 528i's dynamic capabilities can now be further stretched with four-wheel drive, as the xDrive option's rear-axle-biased torque distribution largely preserves the 5's rear-drive character.
High Tech, Low Consumption
And Eco Pro? It's about fuel economy strategies for both you and the car. The car's contribution is to lower the energy demands of the air-conditioning and assorted electrical systems such as the heated front seats, while providing you with some fuel-saving driving guidance. This includes an infotainment display whose bar graphs track the car's consumption over the previous 15 minutes while providing a rolling average. That's good, but the occasional appearance of rather obvious driving tips, such as "accelerate moderately" will irritate some drivers.
The 2012 BMW 528i is a car with an unusual breadth of personality, ranging from comfortable econo-sedan to sporting four-door. And this efficient new twin-turbo four allows it to pull off these character switches with conviction. Yet it's not a car of split personality. The satisfying way in which it gels makes it easy to understand why this is the best-selling sedan in its class, worldwide.
Originally Posted by Jaypod View Post
You sound like my buddies who have AMG's - Slam the gas, slam the brakes...
      10-06-2011, 04:28 PM   #2
M-Power111
M-Power111's Avatar
Drives: Not a BMW....yet
sounds good, im all for the efficiency of the new turbo fours, bring em on.
BMW=
      10-06-2011, 04:44 PM   #3
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25114
Drives: '22 Chalk Gray Porsche C2S
Eeeefissshhhhsinnnnnseeeeee!
      10-06-2011, 05:26 PM   #4
E92LNGCGY
439
Drives: F97/Q5/982 GT4
Once again very positive review of the 4 banger.
      10-06-2011, 07:26 PM   #5
Ateam
88
Drives: M3
I understand technology and efficiency and equal performance with less cylinders but is anyone else just plain sad that the NA inline 6 is gone?
I really think bmw underestimated how much the amazing SOUND of their I6 engine was really responsible for so much of the enjoyment of driving the car for the true driver. I grew up loving and wanting an inline 6. I loved the mechanical sound. I never will forget my first I6 in n52 form. 255hp , 7k rpm and the sweetest engine sound. To think that will never be heard again is a bit sad. In retrospect I should have kept that car.
      10-06-2011, 09:21 PM   #6
BMW_ACURA
Drives: 2011 535I SPORT/PREM
Will you pay 55K for a 4cyl car? even if it has good torque?
      10-06-2011, 09:22 PM   #7
newBMWownr
Drives: 335xi
Next option: Active Sound Design (http://f10.5post.com/forums/showthread.php?t=588968) to make it sound like an in-line 6.
Fearless prediction: Option Price: $5K, approximately the same as the base price difference between a 528i and a 535i (Just kidding)
      10-06-2011, 09:32 PM   #8
mit
Drives: 528
"The culture of the six is gone, but there's more honest muscle to this engine. Those familiar with a BMW straight-6's smooth-spinning ways will miss it some, but it makes the 5 Series a better car. There's some refinement missing, but the return of lighter fuel bills, more torque and extra entertainment is a worthy trade."
To many, this tiny paragraph pretty much summed up the whole review of the car. To me, removing 2 cylinders, adding a turbo and selling the car at about the same price just don't sound right.
      10-06-2011, 10:55 PM   #9
M5007
M5007's Avatar
Drives: 2014 M5 Competition Package
I still like the straight 6
      10-06-2011, 11:21 PM   #10
ORIGIN M.
3161
Drives: ///M
It's a welcome newcomer.
I just know it will never tow the weight the 6 is able to. Period
      10-06-2011, 11:37 PM   #11
BMW BRAD
BMW BRAD's Avatar
Drives: F10 535d M, F31 328d M
Meh..................
[SIGPIC]
      10-06-2011, 11:39 PM   #12
THE JEDI
Drives: 2005 Z4 2.5i
Man thats a lot of money for a 4cyl....don't know if I could take the pointing at me behind my back.....
      10-07-2011, 03:38 AM   #13
KinG12sKy
KinG12sKy's Avatar
Cambodia
18
Drives: Evoque, RR Vogue AutoBio, M4
Im LUCKY i got the 6 banger!!! woot!!
      10-07-2011, 04:54 AM   #14
Evice
Evice's Avatar
194
Drives: E92M3
I do not understand people that says that's alot of money for 4 cylinder....How do you just price the car just with the engine config? or how sophisticated that I6 was so that it was "worth" it? C'mon...
F1 agreed on 4 cylinder turbo 1.5L cars, so they are worth like a Honda Civic?
      10-07-2011, 06:56 AM   #15
elias
elias's Avatar
81
Drives: M4
BMW made their reputation and success on the I-6 not the I-4 can't forget where your roots are and if you do you may forget where your going. I understand the rational behind it I just hope BMW doesn't get too greedy and
start eliminating the I-6 all together.
      10-07-2011, 07:05 AM   #16
sieben1973
Drives: 2011 "dark grey" 528i
I got mine
I was stupid to get rid of my 328i
should have kept that one too
One you lock the target
Two you break the man
Three you slowly spread the net
And Four you catch the man
      10-07-2011, 07:12 AM   #17
heart_doctor
Drives: 2017 M2
No f'n way .... Mercedes here I come ....
      10-07-2011, 08:28 AM   #18
jmsent
12
Drives: VW GTI
Mercedes now offers an I6 engine? Who knew?
      10-07-2011, 08:55 AM   #19
KSERGEI-BY
KSERGEI-BY's Avatar
47
Drives: Skoda Kodiaq 2.0 tdi DCT
No. Just V6. U can have 335 with I6 tt.
      10-07-2011, 08:58 AM   #20
mkoesel
Moderator
Drives: No BMW for now
Actually the I4 plan was scrapped. They are going to be using V6s. And they are 1.6L, not 1.5L, btw.
But yeah, I agree that cylinder count and price needn't correlate. Performance is what is most important. I'm not saying I won't miss BMW's naturally aspirated engines. But I don't think pricing should be adjusted downward just because they are going away either.
      10-07-2011, 09:05 AM   #21
mkoesel
Moderator
You mean the E350? That's the same price range as the 535i, give or take a couple thousand. Mercedes doesn't offer a lower end model in this class like BMW does.
      10-07-2011, 09:26 AM   #22
wannabe
wannabe's Avatar
12
Drives: 2008 BMW 335i e93 6MT
So, switching engines, start-stop, and 8-speed automatic only yielded a max 2 MPG increase?
This doesn't make sense. Why switch out the engine at all, unless they are trying to save weight on the front of the car.
5post
