Help! rubbing! authentic m6 wheels!
10-12-2011, 01:27 PM | #1 |
Rep 179
So i need your guys help ASAP!
i have a 2006 330i e90, lowered on megan coilovers, my fenders are rolled, and here are my wheel specs: front: 225/35/19 they are 8.5 ET: 12 rear: 235/35/19 they are 9.5 ET: 17 there is rubbing where the fender meets the front bumper, and where the quarter panel meets the rear bumper. my coilovers are maxed out in the front, and the rear is a lil raised, and they are set to stiff! i am going to get an alignment tomorrow, what specs should i get for the alignment? i know i have to raise my car a little at well too.. here are pics how the car is sitting right now |
10-12-2011, 01:29 PM | #2 |
Rep 3,879
You need to trim the mount in the rear bumper, and remove the front bumper bracket for a fitment like that.
no amount of camber will help the rear, you could Toe it, but then you would not drive straight. |
10-12-2011, 01:31 PM | #3 |
Rep 4,709
I'm surprised that you were able to fix M6 wheels on your car at all.
A couple degrees of negative camber may help, but that offset is still less than ideal. |
10-12-2011, 02:02 PM | #4 |
BimmerPost Supporting Vendor
2042
Rep 25,989
With a bit of trimming you could probably eliminate rubbing around the tabs. A lot of people with bumpers designed like that on other cars usually trim and relocate the screws for added clearance.
VMR|Wheels | 714.442.7916 |
10-12-2011, 10:26 PM | #6 | |
Rep 179
cool thanks! i will do that tomorrow, yeah i do not want to toe it! will run about -2 camber in rear, and trim the mount and remove front bumper bracket. |
10-12-2011, 10:31 PM | #7 |
Rep 179
the guy who rolled my fenders told the same thing let the rubbing notch itself since its plastic..but it makes a lot of noise right now, just dont want to damage my tires since i just bought them last night!
ill have to drive to my mechanic's doing 25mph with my hazard lights blinking, pissing off everyone driving behind me haha thank god he only lives 3 miles away! also, is it normal that the passenger side sits lower than the driver side? |
10-12-2011, 10:41 PM | #8 | |
17
Rep 329
2007 328 Jet black||M3 rear bumper|LED license plate|220M 19's staggered|Redlines|carbon fiber wrapped interior|
10-12-2011, 10:42 PM | #9 |
MOE
214
Rep 2,530
shave offset
10-12-2011, 10:57 PM | #10 |
Rep 179
10-12-2011, 11:04 PM | #11 |
Rep 5,367
add 3 of these on each side (rears) and max out the rear camber. Next time get a 255/30 rears.
http://www.fk-shop.de/en/Suspension-...ser-17-mm.html
You can follow my builds on IG: Tee212 |
10-12-2011, 11:58 PM | #12 |
48
Rep 281
A little of everything, you should start with the least expense trial, you can camber and see where that takes you but you can always shave the wheels 3mm, all ideas on above threads are correct, good luck and let us know the end result and what you did to make it work.
10-13-2011, 12:48 AM | #14 | |
Rep 179
yeah this thread has nice advice, im not too much into the wheel shave, heard a lot of bad stories about it |
10-13-2011, 12:49 AM | #15 | |
Rep 179
10-13-2011, 04:17 PM | #16 |
Rep 967
Drives: E92 335xi, 2010 Boxster S
Nice setup ,
Pulling and shaving should take care of the rear easy ( I have 265s on my 9"ET22 wheels and rolling was enough) for the front I would have tried 215s I have taken the liberty to copy your pictures to this thread BTW http://www.e90post.com/forums/showthread.php?t=457790
10-13-2011, 08:57 PM | #20 |
Rep 5,120
10-13-2011, 10:01 PM | #21 |
Rep 1,007
Lol, you're not running much of an aggressive fitment...that offset is the key though.
IMO, I (ME, Personally) would. - Leave car as is. - Camber it in just a TAD BIT. - Let the rubbing take care of those spots :P You said you already rolled your fenders? There are spots like you said...where the bumper meets the fender in the front, that spot will always rub unless you relocated (as stated in this thread)...the rears, you have to trim that little piece of metal down (where bumper meets rear quarter panel) even if you roll, there is going to be a pointy fold there.
10-14-2011, 10:09 AM | #22 |
Rep 179
Tags |
wheel fitment |
