Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > offset question?
      10-12-2011, 07:54 PM   #1
M4CXG82
M4CXG82
M4CXG82's Avatar
41
Drives: 2022 M4 Comp Drive
offset question?
will these fit a 2007 e92 335i coupe?
front 19x8.5 offset 35 on 235/35
rear 19x9.5 offset 43 on 275/30
      10-12-2011, 07:56 PM   #2
Express
Express's Avatar
Israel
369
Drives: 06 330i
2006 BMW 330i  [8.30]
horrendous offsets
      10-12-2011, 07:56 PM   #3
SpmnE9zero
DENY THE WORLD THAT SURROUNDS YOU
SpmnE9zero's Avatar
Drives: JB 33ZERO
2006 330xi  [0.00]
Fronts will be spot on.
Rears will be tuckin a bit. Could probably get away with a 10mm spacer without rubbing with no problem as that will take you to an et33 in the rear which is def doable.
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler |
Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers |
      10-12-2011, 08:00 PM   #4
SpmnE9zero
SpmnE9zero's Avatar
Drives: JB 33ZERO
2006 330xi  [0.00]
Originally Posted by express705 View Post
horrendous offsets
hahahaha well yes Allen this would be a nightmare for you. However most are not pushing the envelope of width as you typically do so well.
op Allen has a point. It all depends on what you are going for. If you are looking for something that fits with some room for adjustment in width, then yes these will work. If you are looking for a flush or a bit of a poke with out the need for spacers than these are not the wheels for you. They are a bit conservative.
For instance, I am running et20 in the rear, I did however roll my rear fenders a bit. So it all depends on what look you are trying to obtain.
Allen has pushed the limits with poke and stretch so this set up would drive him nuts.
      10-12-2011, 08:02 PM   #5
M4CXG82
M4CXG82
M4CXG82's Avatar
41
well i dont want them wide that i have to roll my fenders. but i dont want them tucked in more than my stock rears 18 x 8.5 189's
      10-12-2011, 08:03 PM   #6
Express
Express's Avatar
Israel
369
Drives: 06 330i
they will be tucked in more.
      10-12-2011, 08:04 PM   #7
#Tee
#Tee's Avatar
557
Drives: yes
might as well put on some 285
You can follow my builds on IG: Tee212
      10-12-2011, 08:05 PM   #8
SpmnE9zero
SpmnE9zero's Avatar
Drives: JB 33ZERO
2006 330xi  [0.00]
then throw a 10mm spacer on the rear and your golden.
fronts will be fine.
      10-12-2011, 08:06 PM   #9
tibra1
127
Drives: 2011 ZCP M3 - 2007 335i crashd
Stock et on 189s - front 34 rear 37 and i assume u have a 255 tire now.. U are going to run a 275 tire w 43 et.. so u gone be tucked in some on the rear..
Depending on type of tire (whether they run wide/narrow) u have to be concern with rub on the suspension side...i dont know exactly how much space u have there..im sure others can chime in.
      10-12-2011, 08:08 PM   #10
M4CXG82
M4CXG82
M4CXG82's Avatar
41
is a 10mm spacer safe to drive fast on? im worried bc i drive a 335i and i drive it fast. a 10mm spacer in the rear scares me at top speeds
      10-12-2011, 08:09 PM   #11
Express
Express's Avatar
Israel
369
Drives: 06 330i
get extended bolts. make sure they are hub centric.
why not just buy rims with the proper offset?
      10-12-2011, 08:10 PM   #12
M4CXG82
M4CXG82
M4CXG82's Avatar
41
tires are Bridgestone Potenza RE 050's
what size tires do you recommend for the rear?
      10-12-2011, 08:11 PM   #13
M4CXG82
M4CXG82
M4CXG82's Avatar
41
getting a great deal on these
      10-12-2011, 08:16 PM   #14
tibra1
127
265 is always the safe bet..not to say you cant go with 275..there are many guys that run that size.. r going from RFT potenzas to non-rft potenzas? another to keep in mind is you increasing the stagger size which will increase understeer..optimal stagger differential should be no more than 30mm
My OEM RFTs w RE 050's horrible tires..but they were RFTs
      10-12-2011, 08:23 PM   #15
SpmnE9zero
SpmnE9zero's Avatar
Drives: JB 33ZERO
2006 330xi  [0.00]
I would run 235/35/19 front and 265/30/19 rear.
      10-12-2011, 08:26 PM   #16
M4CXG82
M4CXG82
M4CXG82's Avatar
41
so if i get these tire sizes ill be good without spacers?
wont looked too tucked?
      10-12-2011, 08:33 PM   #17
SpmnE9zero
SpmnE9zero's Avatar
Drives: JB 33ZERO
2006 330xi  [0.00]
oh no, not without spacers. without spacers you are gonna look tucked no matter what.
I have ran 10mm spacers on numerous occasions with zero issues. as long as you get a spacer built buy a reputable business you should be fine. given they are installed properly with extended bolts (which typically come with 10mm spacers) and torque them down properly.
people track their cars with 10mm spacers all the time. if you dont want to run spacers but dont want to look tucked... I suggest looking at a different set of wheels.
      10-12-2011, 08:50 PM   #18
asian010
asian010's Avatar
Drives: 335i
i say get a 15mm spacer
      10-12-2011, 09:09 PM   #19
SV Concepts II
SV Concepts II's Avatar
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
+1
      10-12-2011, 09:19 PM   #20
M4CXG82
M4CXG82
M4CXG82's Avatar
41
just what i needed to hear. thank you
now i feel comfortable riding on spacers.
i will purchase 10mm spacer. any brand you reccomend?
      10-12-2011, 09:25 PM   #21
M4CXG82
M4CXG82
M4CXG82's Avatar
41
how about these 12.5mm spacers?
http://www.turnermotorsport.com/p-12...cers-pair.aspx
      10-12-2011, 09:29 PM   #22
tibra1
127
APEX..hubcentric and well made..they sell a 12mm which is perfect
Express put me on to em...
http://www.apexraceparts.com/Wheel-A...ries_c_40.html
