Wheel noob- help a brother out
10-14-2011, 04:28 AM | #1 |
Rep 752
I know, I know. I apologize. This will be my first set of aftermarket wheels and I need some advice from the veterans. I don't want anything crazy like fender rolling or rubbing so keep that in mind.
Here's what I'm looking at: http://www.**********s.com/Velocity-...tyle-Wheel.htm Currently my selections are front: 19x8.5 ET35 rear: 19x9.5 ET33 Is there any major factors between a square setup and a staggered setup? Strongly suggest one over the other? I have all-wheel drive. Also, this may sound ridiculous, but how would I determine what size tires to get? Thanks
2001 Chevy 2500HD Duramax
2003 VW Jetta TDI 2012 BMW F800GS 2024 BMW M2 BSM 6MT Carbon Package |
10-14-2011, 06:07 AM | #2 |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
SpmnE9zero in to "help a brother out" :/
Ok couple of things to keep in mind. VMR wheels are a gravity cast wheel, meaning they are among the weakest wheels on the market in terms of bending and cracking. I see you are located in NY, if this is in fact the case, you may want to re-think going with a gravity cast wheel and stepping into at least a low pressure cast or flow formed wheel. They tend to hold up a good bit better under less than normal driving standards such as potholes. Having said that, the wheel you have chosen... the V701, man that is a great looking wheel! One of my personal favorites. Good for you, they are a rep of the Advan RS wheel which is in fact a flow formed, 1 piece wheel. Now obviously with better products, the price goes up. Now if you dont want any rubbing or rolling of fenders, the offsets you have chosen are spot on for a staggered set up. I am an xi as well and run staggered, most of us on here do. The advantage of staggered is merely aesthetics. The advantage of square setups are rotating wheels to opposite corners and running more of an oem setup as some believe staggered on xi will hurt the transfer case, I have yet to see proof of this. You should be fine running a staggered set up as long as you run 235/35/19 front and 265/30/19 rear. This set up will get your parameters closest to the proper tire ratios. Hope this helps Shane
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
10-14-2011, 03:47 PM | #3 |
269
Rep 6,093
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
The VMR V701 is a beautiful wheel indeed. The xi (awd) models are rear wheel drive biased, so you will be fine running a staggered setup. The sizes you have chosen for your vehicle are perfect and you should experience no rubbing. 19x8.5 ET35 front with a 235/35/19 tire and 19x9.5 ET33 rear with a 265/30/19 tire is the recommended setup for your car. All finishes are available for the wheel. Let me know if you have any questions.
10-14-2011, 05:33 PM | #4 | ||
Rep 752
10-14-2011, 06:28 PM | #5 |
475
Rep 13,583
Drives: JB E92 335i
All the above is correct. All in all, it comes down to your personal choice and of course your budget on a set of wheels. You'll be able to fit the 19x8.5 ET35 with a 235/35/19 up front and the 19x9.5 ET33 with a 265/30/19 in the rear without any issues on your xi aka x-drive model 335. You will not have any rubbing issues and do not need to modify your fenders in anyway!!
10-18-2011, 09:38 PM | #6 |
Rep 5
Hey there...
I hate to thread poach, but it seems your question has been answered thoroughly and rather than start yet another "Noob in need" thread, I'll ask my question here! Will this staggered setup work on an e-91? i've also got the x drive model. I'm looking at a set of 359m reps in Front: 19x8.5 et35 Rear: 19x9.5 et35. Will this fit right with the et35 in the rear? thanks and sorry for thread jacking!! |
10-19-2011, 11:07 AM | #7 | |
269
Rep 6,093
Drives: E90 M3
10-19-2011, 02:32 PM | #8 | ||
BimmerPost Supporting Vendor
2040
Rep 25,989
Those sizes for wheels and tires will fit perfectly at stock height with no rubbing issues whatsoever!
VMR|Wheels | 714.442.7916 |
