Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Help on wheels fitment FOR xi e90
      10-20-2011, 10:41 PM   #1
seasonal
Drives: ACTIVEHYBRID 3
Hello everyone, apologies if this question had been asked before. I have a 2008 pre-lci 335xi 4dr sedan (non sport, completely stock)
I am looking to buy a set of wheels from a fellow forum member and here are the specs:
Front 19x8.5 ET43
Rear 19x9.5 ET 21.5
Is the offset too aggressive in the rear?
what do i need to do to make them fit? i.e. Rolling the rear fenders?
I am relatively new to the World of BMW and any advice would be really appreciated
Thanks very much!!!!
      10-20-2011, 10:57 PM   #2
///M3NACE
///M3NACE's Avatar
168
Drives: E36 M3, E36 Vert , E90 N52
Too aggressive but will work because A. Your stock and B. Your an XI ( sits higher). If your dropped these will rub and way to aggressive without fender rolling. Im on 19x10.5 offset 20 and fenders rolled and slammed and i rub. BTW you can run that offset in the front but its going to stick in a lot. Run a 15mm spacer and youll be fine. 34-37mm offsets are stock i would stay in the range of 25-35mm range.
      10-20-2011, 11:10 PM   #3
seasonal
Thanks for your advice, I suppose that's what I should be looking for in terms of offset 25 - 35mm range.
My goal is to find a set that fits easy with no rubbing/fender rolling so I will have no worry when I drop on a KW V1 next spring.
Thanks
      10-20-2011, 11:17 PM   #4
///M3NACE
///M3NACE's Avatar
168
Worst case do a little neg camber and roll fenders
      10-20-2011, 11:22 PM   #5
seasonal
ya, that's what I am trying to avoid. I have gone through these -3 camber and fender rollings and flush look with my previous car (EVO X). Right now just wanna enjoy the refinement and comfortable ride of a bimmer.
So my goal is probably to find a set that looks nice and not having to do any additional work (adding spacers are fine). and put on a set of V1 and I am all set.
But thanks very much for your advice again.
At least now I know what wheel offset I am looking for and trying to avoid.
Thanks
      10-21-2011, 08:59 AM   #6
Pcemkr
Pro Hater
49
Drives: Low and slow
9.5" et20 is no problem, don't listen to that ^ dude.
      10-21-2011, 09:13 AM   #7
SpmnE9zero
DENY THE WORLD THAT SURROUNDS YOU
SpmnE9zero's Avatar
Drives: JB 33ZERO
2006 330xi  [0.00]
Wrong answer!
I am running 9.5 wide in the rear with 265/30/19 on H&R Sports with rolled fenders and still rub when I hit a major dip in the road.
If you dont roll, and you lower the car, you are going to rub... no doubt about it.
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler |
Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers |
      10-21-2011, 11:08 AM   #8
Pcemkr
Pro Hater
49
Originally Posted by SpmnE9zero View Post
Wrong answer!
Then you're doing it wrong. Run a 255 and/or camber and it won't rub.
I'm lowered on 11" et32 (7mm out more than 9.5" et20) and do not rub.
      10-21-2011, 02:47 PM   #9
seasonal
Will I rub with 265 tires in the rear with stock suspension (non sport), no rolled fenders and no neg camber?
Would it help if I do 235 front 255 rear to avoid rubbing?
      10-22-2011, 11:11 AM   #10
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Point is, not everyone will adjust camber and run stretched tires to make it fit.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      10-24-2011, 08:07 AM   #11
Pcemkr
Pro Hater
49
He asked what he needs to do to make them fit.
      10-24-2011, 08:27 AM   #12
seasonal
Thanks for everyone's input!!! I think running 255 tires on 9.5 wheels are not too stretched? I even saw on the AC Schnitzer website that's the recommended tire sizing for E90.
Again, thanks guys for your input, I have made up my mind to get these wheels. Eventually if I drop my car, I will probably be doing coilovers with camber plate and run neg -2 camber and that should be fine.
Cheers
      10-24-2011, 09:55 AM   #13
Pcemkr
Pro Hater
49
Yes, e90post has just adopted habits of being overly conservative, and everyone just regurgitates the same old info.
