New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > E89 Z4 Classifieds > Commercial Z4 Classifieds
      10-27-2011, 03:29 PM   #1
ModBargains IV
ModBargains IV's Avatar
Drives: e92 335i, 135i, E46 M3, 540i
Location: 1721 E. Lambert Rd. Unit C, La Habra, CA 90631
**********s.com | KW V3 for E89 Z4 | In stock & ready to ship!
**********s is proud to present to the E89 Z4 community KW V3 Coilovers!!!
[IMG]http://www.**********s.com/images/Products/KW_Coilovers/KW_head2.jpg[/IMG]
Call in today for the ABSOLUTE LOWEST PRICE on all KW Coilovers. Please give me a call at (714) 582-3330 ext 8003 for the special price !!
About KW Coilovers
Is your Vehicle looking a little too high? Do you still feel insecure about the sharp turns you attempt around the corners? Is your current body kit not doing the job of creating that AGGRESSIVE appearance? Treat your vehicle and yourself with the best suspension system out there--KW's Coilovers! Not only does this system lower your car perfectly, but it provides HUGE performance benefits.
KW designed and manufactured every coilover to CUSTOM fit your vehicle, unlike other coilovers that may be a "special one-coilover-fits-all", guaranteeing MAXIMUM handling and performance for your vehicle. Along with handling, this system makes sure your car is given a perfectly AGGRESSIVE stance, not a vehicle that's touching the floor. Maybe you're not the one for aggressive looks and ultimate performance, but for comfort. Well, KW took that into consideration, and integrated adjustable comfort technology.
[IMG]http://www.**********s.com/images/Products/KW_Coilovers/4_reason_02.jpg[/IMG]
KW is known for their signature colors, individuality, quality, and security. Take a look below to read more into KW V3!
KW Variant 3
Race Technology for the Road with: Adjustable Compression Rebound Dampening
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the high speed set-up, so decisive for driving comfort, has been preset by our engineers
- Independently adjustable damping technology -rebound and compression damping
- inox-line stainless steel technology at no extra charge
- Individual height adjustment
- German TUEV-tested adjustment parameters
- High-quality components for long life
- Comprehensive documentation for ease of use
- Infinitely adjustable rebound damping
- 14- level adjustable compression damping
- Unique, independently functioning damping power adjustment
[IMG]http://www.**********s.com/images/Products/KW_Coilovers/variant2.jpg[/IMG]
What are Coilovers?
A coilover suspension basically gives you a matched lowering spring and shock absorber combination with the added benefit of adjustable ride height and spring rates through a moveable spring perch or perches. Coilovers are to your car's advantage by reducing unsprung mass, increasing suspension travel, and allowing the car to be corner balanced.
Why do KW's cost more than other Coilovers?
The answer is simple, you get what you pay for when it comes to vehicle suspension. As such a crucial component of your vehicle, suspension is definitely something you do not want to cheap out on. KW is known for their reinforced and durable suspension components. KW's coilovers have been carefully crafted and designed by studying the flaws of competitors and improving on them. In addition KW coilovers can go lower than just about any other brand and allow you to set your car to a "slammed look", "sporty look", or anywhere in between. In the unfortunate event that anything should happen to your coilovers, KW's warranty backs all their products from manufacturer's defect.
Function
Infinitely adjustable within German TUEV-tested adjustment parameters
Shortened struts for increased spring travel
Trapezoidal threads for simple height adjustment
Three different damping technologies for individual adjustment
Elastomer bump stops with integrated dust boot protection
Easy to read documentation
Ready to use comprehensive solutions
Visually perfect – safe and unique motion dynamics
Quality
Strut housings in inox-line stainless steel technology
Anodized aluminum spring collars and add-on pieces
High-quality, high-tensile racing springs
Special ventilation and sealing system
High-quality damping components
Hardened, chromium-plated piston rods
Special guide and sealing systems
Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
Any questions, feel free to call me at ************** or ask for Frank. My email is Frank************.com.
-Frank
      02-03-2012, 01:58 PM   #2
ModBargains IV
Got a couple more sets left in stock
zpost
