2 Image Dynamics Q 1200.1 amps mint condition
10-29-2011, 06:14 PM | #1 |
Rep 33
IF you know anything about car audio then you know these amps are top of the line SQ amps and retail for 1000 dollars apiece. They are both in pristine condition and have hardly been used. You could say that they are pretty much new. they both have the remote bass knobs that come with them. I am looking for 450 apiece or willing to make a deal on both together. Class A/B Mono-Channel Amplifier Audiophile Grade NE5532 Opamps Mosfet power supply 1Ohm stable high current design High current bi-polar output design Soft start / mute circuit Remote bass level control Fully-Variable Phase shift input: 2 channel RCA style differential balanced mode Channels 1&2 Crossover: Fully-Variable 50~250Hz (12 db per octave ) LP Sub Sonic Filter: Fully-Variable 15~45Hz ( 12 db per octive ) Channels 1&2 Bass Eq: Fixed at 40Hz with 12db of boost input Sensitivity: 150mV~5.0V RMS input Impedence: 20K ohms rated power ( Mono ) : 500 watt @ 4 ohm ( 14.4 VDC ) rated power ( Mono ) : 800 watt @ 2 ohms ( 14.4 VDC ) rated power ( Mono ) : 1200 watt@ 1 ohm ( 14.4 VDC ) Frequency Response ( All channels ): 10Hz~30KHz +/- .5db THD + Noise ( All channels ): <.1% S/N Ratio ( All channels ): >100db Damping factor @ 50hrz: >100@2 ohms All speaker outputs connections: Accept up to 8 AWG wire power input and ground connections: Accept up to 4 AWG wire Dimensions ( L x W x D ) 18.5 in. x 8.625 in. x 2.0625 in. 470 mm x 219 mm x 52.3 mm |
