Bridgestone RE960 RFT 3rd gen vs Conti Pro Contact SSR RFT
11-06-2011, 07:37 PM | #1 |
Rep 31
I own a CPO '06 330i with 17" OEM run flat. They are starting to wear down and I'm trying to decide what to replace them with. I just moved to Chicago and am not use to driving in snow. Here are my driving habits:
-I commute to work on the train and drive my car about once a week. -When I do drive, it is hardly ever on the interstate and is only to go get grocceries or to the store (max 40MPH). -I live in the city (Lincoln Park) and the roads are almost always plowed and salted. -Chicago has tons of pot holes and I'm constantly concerned about blowing out a tire, bending a rim, or blowing out my suspension So given these situations I think it is best to stay with AS tires and not go with a seperate winter setup because I don't think it makes sense with as little driving as I do. I've searched the forum and I've narrowed it down to these two tires based on what the users and Gary@tirerack has said. I've noticed that there isn't much out there on the RE960 RFT 3rd gen as this is really the only thing that I found. http://www.tirerack.com/tires/tests/...y.jsp?ttid=156 What is everyone's suggestion if they had to pick between these two tires? |
11-07-2011, 06:40 PM | #2 | |
Rep 2,547
11-07-2011, 09:34 PM | #3 |
Rep 5,627
If you decide to opt for a non RFT, you should seriously consider the Conti Extreme Contact DWS.
Otherwise, I think I'd pick the RE960 RFT. Tom |
11-08-2011, 10:54 AM | #4 |
Moderator
369
Rep 4,745
Between the two runflat all season tires in that size the Conti ProContact SSR has a bit softer ride and is a bit quieter while the RE960 A/S RFT would have an advantage in wet grip as well as better handling and steering response.
Tires http://www.tirerack.com/a.jsp?a=AH8&...ires/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
11-13-2011, 03:14 PM | #5 | |
Rep 2,547
11-14-2011, 07:45 AM | #6 |
Moderator
369
Rep 4,745
The 970 is a non run flat tire. As a result, it has a softer ride and slightly slower steering response than the run flat RE960 A/S rft.
The 970 should have longer wear and better wet traction.
