Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Stage II Dinan Tune and Exhaust
      11-12-2011, 09:03 PM   #1
vzehler
Drives: 2007 BMW 335i
Unfortunately, this is my first time out to run my car but I think these numbers seem low for a Stage II tune and Dinan Exhaust. There was a head wind of about 15 mph but I didnt think it would make that much of a difference. My car recently had a software update... Is there a chance that they erased my tune?
Here's a picture of my time slip for my best run of the day.
      11-12-2011, 09:51 PM   #2
RnmEvo9
247
Drives: 2007 335i
If you had a software update, then there is a high probability that your tune was erased. Trapping 102mph in the 1/4 mile is basically what stock 335s do...
      11-13-2011, 11:39 AM   #3
skow
skow's Avatar
Drives: 2016 F36 Gran Coupe xDrive
Yes most likely your tune got wiped if you had a software update. My local dealer isn't Dinan authorized so I have to take it to a local shop that is after i get any software updates (local sop doesn't charge to re-apply a tune)
      11-13-2011, 02:20 PM   #4
vzehler
Thats kinda what I figured... How about those 60' times?
      11-13-2011, 02:22 PM   #5
vzehler
Skow,
Have you ever ran yours in the 1/4. I see you have about the same mods and just curious how you've done, if you have.
      11-14-2011, 08:38 PM   #6
skow
skow's Avatar
Originally Posted by vzehler View Post
Skow,
Nope, I'm more inclined to do track days (turns are more fun). I have been meaning to go at least once though, I'll post my time if i go in the near future.
      11-16-2011, 05:19 PM   #7
Turbomatic
Drives: E36 M3, 335xic, Rav4
That is about right with just an exhaust and no Dinan II. I ran 13.0 - 12.9 with Dinan and exhausta and I have an Xi which is heavier and slower. Go to Dinan authorized place. Good luck.
      11-21-2011, 07:10 AM   #8
JStang
JStang's Avatar
562
Drives: FDB M3 CS
Wouldn't you know it if your tune was missing? I sure as hell can tell when I uninstall mine.
      11-22-2011, 07:42 AM   #9
Javy
e92javy
Javy's Avatar
Drives: Alpine White E92 M
I had a software update on my car at an unathorized Dinan dealer also. I believe it got wipped. I have'nt had a chance to take it into a dinan dealer since the closest one to me is 2 1/2 hours away.
The reason why im not that sure is because I bought the car used then two days later I took it to get serviced to make sure everything was up to date.
      11-24-2011, 06:59 AM   #10
vzehler
Turns out the tune was indeed deleted last time service was done.. All is well and back to normal.. I bought the Cobb Accessport on Pre-Black Friday sale though so I guess getting the tune put back on was a bit of a waste.
      01-01-2012, 07:37 PM   #11
matty088
Drives: 335i
these "software updates" are performed how?
how does one know when one is required or performed?
Anways happy to see u uncovered what the issue was!
btw...i am thinking of doing the stage 2. what kind of hp and 1/4 mile times are guys seeing?
      01-17-2012, 06:00 PM   #12
justinco
btr.life
Drives: e36
1994 BMW 325is  [0.00]
2009 BMW 335xi  [10.00]
2005 BMW 330i ZHP  [0.00]
I'm surprised you couldn't tell if the Dinan stg2 was gone???
My car was re-flashed to stock after HPFP replacement recently at my local dealer. I told them I had Dinan stg2 and they told me the flash would erase it. Since they weren't an authorized Dinan dealer I just took my car to my Dinan auth'd dealer and they flashed the Dinan stg2 right back on.
For the day I was driving the stock tune I could tell a huge difference in power though. Hard to not notice.
Justin
1994 BMW 325is - Project 325 HPDE/TT | 2013 Scion FRS - Project FRS STX | 2017 Subaru BRZ - Project BRZ STX
      01-24-2012, 02:59 PM   #13
BQTuning
Drives: 2012 Z4 sDrive35i M Sport 6MT
1.9 60" Dinan S2 w/exahust will get you 12.9-13.0, but your running Cobb now so lets see how it turns out
Through the OBDII serial port
Everytime you take your car to the dealer you should make it loud and clear "DO NOT TOUCH MY DINAN" and for them to let the tech working on the car know that.
It happened to me...you wont really know unless WOT the car. I started to suspect mine when a PROcede 335i pull too hard and too fast from me vs the many many times we had done the samething
Took it for a dyneo run and I about almost got into it with the shop guy, I took it back to the Dinan BMW dealer to have Dinan S3 reflashed back to it
I apologised later...
      01-24-2012, 03:07 PM   #14
justinco
btr.life
Drives: e36
Hmm, well guess everyone's butt dyno is different. I could tell at partial throttle acceleration that it felt "slower". But then again, I also knew it had the stock flash put back on so I expected it to feel slower.
Did you have Dinan s2 before your s3 flash? Was the power increase noticeable?
      01-24-2012, 03:41 PM   #15
BQTuning
On my previous 335i yes, only my current 335is I went straight to Stage 3 after the 1200 mile break in period. To be exact at 62 miles, before leaving the dealer, I had the Dinan exhaust installed, and at 1300 miles I had the Dinan FMIC installed, and then at 3340 miles Stage 3 tune was flashed.
On my previous 335i when going from S2 to S3 there was a big significant difference. The larger added FMIC and the Dinan CAI made a huge difference w/ a 1 PSI increase between the stages.
      01-24-2012, 05:03 PM   #16
justinco
btr.life
Drives: e36
Nice. The CAI is not needed for stg3 though as far as I know, just the FMIC, right?
Been pondering an upgrade to stg3 someday for a little more power and to keep it simple/reliable for autox and PDX/TT.
Thanks..and sorry OP for the
      01-24-2012, 05:06 PM   #17
BQTuning
The FMIS and the OC is needed for stage 3. The CAI is an added bonus that helps out with intake breathing and helps with gas also
      01-26-2012, 11:10 PM   #18
vzehler
Justin
Well, I bought the car "with the stg II tune" so I hadn't had the opportunity to drive it with or without it.. I just assumed it was what it was until I made it to the drag strip and posted up stock times.
      01-31-2012, 02:23 PM   #19
acj75
acj75's Avatar
Drives: '07 E92 335i
My '07 didn't come with a factory oil cooler, so I got the Dinan Stage 1. I've been to the drag strip 4 or 5 times, and the best I've run is a 12.8 @ 105 with a 1.8 60'. Click my signature for the slip. That same day, I ran 3 consecutive 13.0s, and my usual times are in the 13.0 - 13.2 range with the stage 1.
Personally, I believe there is no need to "upgrade to stage 3 for a little more power" for autox events, etc. I have run faster times than other e9x cars, including M3s and 335s with more aggressive tuning at AutoX events.
After my first season of AutoX and a couple track days, I know that this car with just my mild tune is much more capable than my skill level as a driver. If and when I reach a point that the car is holding me back, I'll upgrade accordingly. Just my opinion. Either way, it's all about having fun. enjoy
'07 E92 BMW 335i
      01-31-2012, 02:59 PM   #20
justinco
btr.life
Drives: e36
Thanks for the input.
I agree, there is no need for more power for autox events. I just said I wanted to keep it simple/reliable for autox. I would like the added power just in general
If I do anything specifically for autox, it will be rims and tires. My plan is to run this summer season as the car sits, and on street tires, then see how much I like it and go from there. I realize the car is much faster then my driver skill level and will probably be like that for a while still.
Justin
