Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d 2011 adaptive headlight ?
      11-23-2011, 05:43 PM   #1
335dM
Drives: 335d m package
i have a 2011 335d with following options: ZFU ZGM ZLH ZLJ
Do i have the adaptive headlight left to right? because it isnt working at all. I have xenon and when i start my car they go up and down but i never see them turning left or right.
      11-23-2011, 06:31 PM   #2
Julesandtrish
Julesandtrish's Avatar
27
Drives: 335d
2010 BMW 335D  [10.00]
If your lights don't move left to right when turning the steering wheel in the same direction (you can do this either while moving or while stopped), then you don't have it.
Enjoy what you drive.
      11-23-2011, 06:34 PM   #3
335dM
it doesnt!
      11-23-2011, 06:37 PM   #4
335dM
how can i be sure i dont have it?
      11-23-2011, 06:55 PM   #5
Park2670
Park2670's Avatar
Drives: Tesla Model 3
Make sure your headlight switch is on the auto position all the way to the left.
      11-23-2011, 08:31 PM   #6
Julesandtrish
27
Drives: 335d
+1 Good point. I forgot to mention this.
      11-23-2011, 09:46 PM   #7
fdriller9
Drives: '06 AW 330xi
2006 330xi  [6.44]
Have someone pull your VO and look for the adaptive headlamp code.
Dealer can pull it. Or if you know a local coder, they'll be able to do it too.
      11-23-2011, 09:58 PM   #8
335dM
It is on auto position.
      11-24-2011, 09:58 AM   #9
cptcrunch
Captain Crunch
cptcrunch's Avatar
168
Drives: 2016 340i
I thought all 335s (i, d, is) have xenons with adaptive headlamps?
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno
Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade
      11-24-2011, 11:28 PM   #10
EPOS
Drives: E90 M3
335d does not have adaptive.
      11-24-2011, 11:49 PM   #11
Park2670
Park2670's Avatar
A US spec 335d most definitely has adaptive headlights.
      11-25-2011, 07:30 AM   #12
hotrod2448
grand poobah
hotrod2448's Avatar
Drives: F80 M3, F10 535i
2011 335d  [0.00]
Absolutely wrong. I know mine does.
      11-25-2011, 11:44 AM   #13
jkman510
Drives: x3 m40i
My 335d has it too.
      11-25-2011, 07:01 PM   #14
nhinnhuckyduc
Drives: F30 328D
You should bring it to the dealer and have them to check it out. Cause all of the 335d with sport or m sport will have the adaptive head light.
      11-25-2011, 07:54 PM   #15
MrPig
MrPig's Avatar
14
Drives: '11 STI, '90 325iS
1990 BMW 325is  [10.00]
Do they? As far as I can tell I don't have adaptive lights. Auto level, yes, but not left/right when making turns. Unless I'm blind and can't tell the difference.
Edit: Quickly building my car to spec on bmw.ca and I see no mention of adaptive headlights. Adaptive brake lights, yes. But not headlights.
      11-25-2011, 08:43 PM   #16
nhinnhuckyduc
Drives: F30 328D
To the best of my knowledge it should have it. All US Spec 335 with the Sport or M sport Should have them. It doesnt say it on the us site as will but im 100% sure that us spec has it. You will know if you have it. It is more noticeable at slow speed like 15 mph i cant tell when im on the highway but i know it work. i was driving behind my brother one day and he say my head light were crazy the auto level was moving the light up and down pretty quick and when i hit the turn it was leveling and moving left and right at the same time. We were doing about 100-130 mph
      11-29-2011, 01:14 PM   #17
Concentric190
Drives: 335d
1997 BMW M3  [0.00]
2009 BMW 335d  [0.00]
1995 BMW M3  [0.00]
make sure your light switch is on the auto position. my 09 sport/prem has it. you can easily notice it pulling in your garage at night.
///Andres
09 335d evolve tuned - 327whp / 490wtq -- 13.0@105
95 M3 Turbo - Built 3.0l s52, PTE74GTQ, AEM EMS & CDI
97 M3 NASA TTB build for 2014!
      11-29-2011, 03:43 PM   #18
igom3
Drives: 02 E46M3 15 F80 M3 16 X5 35d
2016 X5 35d  [0.00]
2015 BMW M3  [0.00]
2002 E46 M3  [0.00]
Those are your fog lights. They will move if you steer left or right.
      11-29-2011, 06:28 PM   #19
jkman510
Drives: x3 m40i
Mine has it. Like others said; It only works if the switch is in the auto positions (who thought of that?!).
      11-29-2011, 06:46 PM   #20
sleeper335d
sleeper335d's Avatar
Drives: 2011 335d- M
The Adaptive Headlights cast their beam in the direction of the curve and ensure better visibility and more safety during night drives on winding roads.
Sensors measure speed, steering angle and yaw (degree of rotation around the vertical axis). Based on this information, small electric motors turn the headlights left or right so the beam falls on the road ahead, guiding you into the bend.
Headlight beam throw control (a model-specific function) means the front headlights are raised at high speeds and lowered at slower speeds, which results in a wider beam for inner-city driving.
The adaptive headlight range control (a model-specific function) takes into consideration the vertical curve of the road. The headlight beam throw control is lowered when driving over a knoll and raised when the vehicle is in a dip.
The result: every single curve is illuminated and the oncoming traffic isn’t dazzled unnecessarily. Driving at night is even safer, particularly when visibility is poor.
Adaptive Headlights are only active when the vehicle is pulling away. They stay switched off when the BMW is in reverse and when the steering wheel is turned to the left while the vehicle is stationary (e.g. when pulling out of a parallel parking ******* to avoid dazzling oncoming traffic.
Adaptive Headlights are complemented by cornering lights. These are automatically activated at speeds of up to 70 km/h and improve visibility in the immediate vicinity of the vehicle, which is useful when driving along hairpin bends, turning or parking.
      11-30-2011, 04:59 PM   #21
335dM
mine doesnt Called a local dealer and ran my VIN and they told me i dont have it! They also said no 335d has it in Canada.
      12-01-2011, 09:40 AM   #22
Concentric190
Drives: 335d
1997 BMW M3  [0.00]
1995 BMW M3  [0.00]
oh yeah, I don't believe Canada had that option. Which is why your other projector has more of a blacked out look to it.
///Andres
