Is the Oil Level Reading Progressive?
12-01-2011, 09:29 AM | #1 |
Rep 3,714
I check my oil level regularly through the on board computer. It was sitting at 3/4 for quite some time and then it went to half for a long time. Today I checked and it was between MIN and half.
Does the readout only show you in blocks of percentage meaning 100%, 75%, 50%, 25% etc or can it show anything inbetween in smaller percentage readings? I ask because I think it's strange that it goes from 3/4 to 1/2 pretty quickly. I don't have any oil drippings on my garage floor so I'm guessing the car is using a little bit of oil (is this normal?) but the reading won't drop little by little. |
12-01-2011, 09:37 AM | #2 | |
Been there, wrecked that.
18
Rep 547
-Brian
~199K miles. I -still- don't fear my 335i. |
12-02-2011, 05:58 AM | #4 |
173
Rep 3,415
The readout sounds like it is working correctly. The readout is showing the status of the 7th quart of oil in the engine sump. It only indicates the status of the 7th quart in 1/4 (25%) increments. When the reading shows "+1 Qt" then it is time to add an additional quart of oil.
If you are concerned about the engine's oil consumption, write down the level reading and corresponding mileage it was read at. Record the data for awhile then you can analyze the trend of oil consumption. |
12-02-2011, 11:32 AM | #6 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Check your oil cooler flange gasket. It is know to deteriorate from heat and cause oil leaks.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
12-02-2011, 04:16 PM | #7 |
18
Rep 547
^^^Actually, it turns out I have two leaks. I thought I just had one - which I fixed by replacing the gasket that mates the oil cooler thermostat housing to the oil filter housing. Surprise! Somewhere there is a another leaker which I need to get around to tracing down.
-Brian
12-03-2011, 04:43 PM | #8 | |
45
Rep 1,754
