BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > iDrive/Nav and iPhone 4
      12-01-2011, 09:38 AM   #1
neovb
Drives: 2011 BMW 335d
For all you guys that have the navigation package and the USB input, does your car support the iPhone 4 for music? All the previous generation iPods work (like my regular iPod 16gb) but for some reason, I have never been able to use the iPhone 4 and the dealer has no clue why.
I know you can use the auxiliary port for sound and the USB port for charging, but then that gets rid of the ability to use iDrive to pick songs/albums/etc.
      12-01-2011, 10:37 AM   #2
BD SM3RF
BD SM3RF's Avatar
Drives: 2015 YMB F80
2015 BMW M3  [0.00]
2016 BMW X3  [0.00]
2011 BMW 135i  [0.00]
This question is in the wrong forum so you may find better answers over in the iDrive/Nav forum but...
I have had no problems using my iPhone 4S. I have a BMW cable the dealer gave me ($80 retail but cheaper on ebay); however, I was also able to pair it with bluetooth and still control it through the iDrive but not with as many functions available when using the Y cable that connects to the iPhone dock and then splits out to USB and 3.5mm jack which connect under the armrest.
I was also able to connect it with just a standard apple USB/dock connector but the sound quality was no good so I am using the BMW Y cable described above. The best option is the $235 snap-in adapter to use with the iPod/USB adapter ($400 option 6FL) I also have BMW Apps ($250 option 6NR) but due to sticker shock of also having to purchase the separate iPhone 4 snap in adapter I have not yet tested the added level of integration that it is supposed to offer.
      12-01-2011, 07:31 PM   #3
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2021 M5 Competition  [0.00]
2016 BMW 550i  [0.00]
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
With the loaners I've had with iDrive, my 4S has worked flawlessly, using my 6FL cable (I always bring it with me when I get a loaner).
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i
      12-02-2011, 06:20 AM   #4
hotrod2448
grand poobah
hotrod2448's Avatar
Drives: F80 M3, F10 535i
2011 335d  [0.00]
I can get both my 4 and the wifes 4S to work using the USB cable. I don't do it often though. If I recall you need to plug it on and hit the music button on the phone for it to recognize it as an ipod. After that you should be able to drive everything through the idrive.
I'm just pissed that I still can't stream music through the the bluetooth using the iphone. I also don't like that the ipod out is only available using the cradle. I don't want to peel my phone out of an otterbox every time I plug it in.
      12-02-2011, 12:18 PM   #5
BD SM3RF
BD SM3RF's Avatar
2015 BMW M3  [0.00]
2016 BMW X3  [0.00]
I initially had a problem with bluetooth music streaming. After pairing the phone which was easy I realized that the default did not include pairing for music. To solve that problem there was a check box under bluetooth options for Music. The option for phone was the only one checked by default after pairing I had to manually select music. After that I was able to stream music over blue tooth.
Ultimately I stopped doing that because every time my phone was plugged into the 6FL cable it would break the bluetooth pairing for music. It appears that iDrive will only allow one connection type per device.
Ultimately I will breakdown and buy a snap-in adapter for my iPhone so I can take full advantage of all integration features. All I use is a Ghost Shield so no case hassles. I like living on the "iPhone 4s" edge.
      12-02-2011, 04:15 PM   #6
neovb
Thanks guys.. looks like I'll try the Bluetooth option. I dont have a cable (I've been reading up and it seems that theyre supposed to be included when you purchase the car, but I never got one) and I dont feel like shelling out $60 bucks.
Maybe Tischer will give me a cable if I ask nicely... I got my car from them and they never included one.
      12-02-2011, 04:58 PM   #7
BD SM3RF
BD SM3RF's Avatar
2015 BMW M3  [0.00]
2016 BMW X3  [0.00]
Its crazy that it doesn't come with the car. My salesman had one that he pulled out of a used trade-in that he have me so I was spared the $60+ rip-off. You can definitely get it cheaper on ebay. You may even find one for sale on this forum. I guess I'll be selling mine once I shell out about $200 on ebay for the snap-in adapter.
      12-02-2011, 04:58 PM   #8
hotrod2448
grand poobah
hotrod2448's Avatar
2011 335d  [0.00]
You should be able to use the standard Ipod cable that you use to plug it into the computer.
      12-03-2011, 07:46 PM   #9
neovb
No, the standard iPod cable does not work. It'll charge the phone, but will show up as "unsupported" in iDrive.
      12-04-2011, 03:17 PM   #10
hotrod2448
grand poobah
hotrod2448's Avatar
2011 335d  [0.00]
I can use the stock Apple USB cable on mine. Your car must not have BMWApps or the combox coded for it. I'm not sure at what point the combox became standard. I've seen someone on here that offers that coding.
      02-23-2012, 12:09 AM   #11
adriang
adriang's Avatar
64
Drives: 2018 BMW X2
i have the same problem as you,,, my iphone 4 is connected to bluetooth so i can do calling through the car, but the iphone is not recognized for music... i tried in the glove box usb port and in the center console... no luck...
      02-23-2012, 07:52 AM   #12
wrickem
Big Beaver Smile
wrickem's Avatar
2101
Drives: What he wants to
Mid September 2010 it became standard
My iphone 4S works fine (mid sept 2010 build) for music/phone/bluetooth music with either Y cable or the Apple cable in the 6FL USB.
For conveninece though, I leave a big ole Ipod Classic permanently plugged in for music and only take it out to update it. It's so much easier than plugging and unplugging everytime I get in my car.
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch
