      12-02-2011, 07:57 AM   #1
Whteverjklasdf
20
Drives: .
BMW SSK for 1M same as that of 135i?
Does any body have any idea?
According to realoem.com the 1M/135 part #s for the 6-sp shifter are exactly the same. So I assume that the various kits (BMW Peft SSK, ActiveAutowerke, etc) that are made for the 135i should also work on the 1M too?
      12-02-2011, 08:26 AM   #2
Sal@AUTOcouture
Sal@AUTOcouture's Avatar
733
Drives: E93 M3, E36 M3
According to our resources its the same as the N55 transmission, so none of the N54 SSK's work. We haven't tried yet tho...
      12-02-2011, 09:12 AM   #3
Franklin Joseph
Drives: BMW
Rogue E has a 1M specific SSK. IND got the first set...waiting for their review.
      12-02-2011, 10:46 AM   #4
Dackelone
European Editor
Dackelone's Avatar
Germany
10528
Drives: N54 e82
Arrow
The 1M uses the SAME 6MT trans as the N55 does. It has been reported in teh past that BMW says the Performance SSK does not fit N55's (and hence the 1M). The reason is bc the N55's use a different shift "arm" or "carrier" than the N54's use.
#1 in the bellow diagram is what I am referring too. This is the "arm" or "carrier".
#8 is the shift lever arm. This part is also changed in the Perf SSK. I would "think" that you could replace the 1M part with the Perf SSK and have 85% of the short feel of the SSK. But I have never seen anyone post about doing such a mod. I would use this shift arm from the Perf SSK: bmw # 25110434217
Bellow is my (stock) "arm" or "carrier" from my N54 after I had the Perf SSK installed. This part is indeed stamped with a N54 logo.
You should ALWAYS replace this ball or plastic bushing/bearing when working on the shifter. I would also order some extra C-clips bc you will loose one... and its a PIA to find one at the dealer when your car is up in the air. Btw... most shops only charge 1 hours labor for the install. That is what my BMW Zentrum charged me. Plus they had to drop the mid pipes to have more room to put those damm c-clips back on.
Also... FYI... here are the shifter throws...
N54 = 80 mm throws (1st to 2nd)
N55 = 70 mm throws
N54 w/Perf SSK 55 mm throws.
Many ppl have said that the Perf SSK is one heck of a great mod. I have to agree. It is a MUST HAVE mod on any 6MT BMW, along with the "CDV delete" mod.
Dackel
      12-02-2011, 12:00 PM   #5
JasonCSU
Drives: '08 135i, '88 325is
1988 BMW 325is  [0.00]
2008 BMW 135i  [0.00]
N55 = 70 mm throws
Dackel
Nice, a 25mm reduction. I may have to look into the SSK. Doesn't the SSK also come with the BMW Performance shift knob and boot as well? I don't particularly want those items, but I suppose I could install the linkage and sell knob and boot.
Delivered in Munich, broken in on the Nurburgring.
      12-02-2011, 12:17 PM   #6
Dackelone
European Editor
Dackelone's Avatar
Germany
10528
Drives: N54 e82
Actually you can order the Perfoamnce SSK as a one box kit of you can order each part individually. And its cheaper when you order each part individually! I did not order nor want the kit's shift knob or the shifter bag. I only wanted the shorter shift feel. It is a great mod!
Here are a few good resources for how BMW shifters work:
http://www.mz3.net/articles/143.html
http://www.understeer.com/onlinestore-shifters.shtml
25mm might not sound like much but its HUGE when you go to shift. It really helps makes teh car feel so much more sportier.
      12-02-2011, 12:58 PM   #7
3val
Drives: 2008 SMG 135i, 2013 X1 2.8
Dan @ United sells the kit w/o the boot and knob!
      12-02-2011, 01:25 PM   #8
JasonCSU
Awesome. Thanks for the info guys.
      12-02-2011, 05:04 PM   #9
mrow
Drives: AW 1M
Slightly off topic but anyone know why they went with the N55's transmission for the 1M over the existing N54 transmission? Just curious.
      12-02-2011, 05:14 PM   #10
MusclezMarinara
Drives: VALNCYA
they are definitely improvements over the MT in my 09 335 n54. vs my 1M
      12-03-2011, 09:14 AM   #11
Whteverjklasdf
20
Drives: .
Thanks for all the info guys!
To add complication to the topic... my incoming 1M is RHD... so i guess i will have to be extra careful when ordering parts in the future... hm...
      12-03-2011, 09:52 AM   #12
Dackelone
European Editor
Dackelone's Avatar
Germany
10528
Drives: N54 e82
Why? The 6MT shift pattern is the same for LHD vs RHD cars.
      12-03-2011, 11:49 AM   #13
Whteverjklasdf
20
Drives: .
well... i wrote getBMWparts.com and they told me that "this kit (OEM BMW Performance E82/88 1 Series Short Shift Kit) is not compatible w/ the RHD version."
      12-03-2011, 11:30 PM   #14
Dackelone
European Editor
Dackelone's Avatar
Germany
10528
Drives: N54 e82
I wonder why? Maybe try asking a local dealer to you? Surely someone has installed a SSK on a RHD 135i. ?
I took a quick look on RealOEM.com when you select a N54 eurpo version of the 15i and also select RHD it shows the SSK being available...
http://www.realoem.com/bmw/showparts...76&hg=25&fg=95
Dack
      12-04-2011, 09:43 AM   #15
Dackelone
European Editor
Dackelone's Avatar
Germany
10528
Drives: N54 e82
I looked around www.RealOEM.com again. Maybe I am missing something but I don't understand why BMW's Performance SSK would not work on a RHD car. The shift pattern is the same as are all the OE parts. Here is a quick comparison of 135i (N54)euro LHD vs RHD models...
LHD stock shifter parts
25117524720 carrier
25117581806 shift lever
RHD stock shifter parts
25117524720 carrier
As you can see the shifting parts are the same for RHD and LHD models. Maybe the shift bag is different? I really don't know why the Performance SSK would not work. ?
LHD Performance SSK parts
25110434218 carrier
25110434217 shift lever
You will also need a new plastic bearing for the shift lever and some extra c-clips incase any of them break or go missing during the R&R.
25111220600 bearing
25117571899 c-clip
      12-05-2011, 04:33 PM   #16
Whteverjklasdf
20
Drives: .
Thanks Dackelone.
i should also look into some UK forums and see about their SSK options...!
      08-27-2013, 08:12 AM   #17
ZA_1M
Drives: BMW 1M
So the BMW SSK will not fit the 1M then....just making sure
      11-29-2013, 12:53 AM   #18
Daniu9394
China
20
Drives: BMW E90 335i /BMW 1M Coupe
Some 1M guys have already installed the BMWP SSK on 1M and it works well. pls see here http://www.1addicts.com/forums/showthread.php?t=879129
      03-14-2019, 02:57 AM   #19
Chilli WonderBoy
Drives: BMW Z3 qp 3.0 & 1M
Hello,
I have a BMW 1M and I am very surprised that during the service it turned out that I have installed "arm" or "carrier" from N54 (with the N54 logo, number 25117524720).
The previous owner had to install it, but for what purpose?
any ideas?
I wonder if I should replace it with the N55, it would be like from a factory.
1addicts
