12-06-2011, 03:24 PM | #1 |
Rep 898
Drives: '69 GT3, GT4, 1M, 912
Bigger Turbos
Not for the purists, but has anyone looked into curing the 1M's asthma above 5500 rpm with some bigger turbos?
It seems some interesting options have become available in the past year such as Rob Beck Turbos (RB Turbos) and ASR, some of which would be visually indistinguishable from stock, but do unleash the beast. It looks like ~450 at the wheels is available boost only, pump gas, in the 15-16 psi boost range. http://www.e90post.com/forums/showthread.php?t=480025 Which makes me think... Are there any differences between our cars and other N54s that would be roadblocks to doing this? Other than the obvious potential reduction in the collector value of the car, of course. Thoughts? I did a search and didn't see any mention of RB turbos here, and I was a bit surprised given the seeming giant-killing potential...
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
12-07-2011, 07:02 AM | #4 |
Rep 3,157
going to our local dealer in Taiwan tomorrow to put down orders for 3 1Ms
turbo upgrades are a must for us in the near future
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
12-07-2011, 10:18 AM | #5 |
BMW obsessed
9571
Rep 10,855
The 1M and 135i share the same part numbers for turbochargers, so upgrading should not be an issue.
12-07-2011, 11:25 AM | #7 |
Rep 898
For you guys that are planning on it, what turbos and tuning solution are you going to go with, if you've decided?
From what I have read, the stock fueling and ability to tune it runs out right around the 450 whp level. Most guys going beyond that now seem to be using meth, though that may change. It sounds like upgrading the fuel pumps, etc, is likely to raise the hp limit soon, as the big turbos could make more power if the fuel was available. I'm just learning, but it currently looks to me like a decent intercooler, down/ midpipes, RB turbos and a flash tune are all you need to get in the 430-450 whp range on pump gas. Boost would only need to be in the 15 psi range (stock overboost is 14.5 psi) so it doesn't seem like it would be a very stressed package, and it would look nearly stock- even a dealer might not know you'd done turbos.
12-07-2011, 11:25 AM | #8 |
BMW obsessed
9571
Rep 10,855
Thus far we have not seen the ceiling of the factory fuel system, so at present I can't say exactly what power level will require a fuel system upgrade. The N54's direct injection fuel system seems to have a very high ceiling indeed. I don't believe a fuel system upgrade will be required until well past the 500 hp mark.
ESS Tuning is at present searching for a 1M owner who is interested in testing their new turbo upgrade. Anyone interested in sending their car to ESS for development can shoot me a PM, and I can make the necessary arrangements.
12-08-2011, 06:42 AM | #9 |
46
Rep 582
Sorry where is ESS located could be interested i know they do great work maybe it would be easier if i did there turbo kit through one of there vendors or somthing since its closer auto coutore is great and i know there a big ESS vendor
12-08-2011, 06:47 AM | #10 |
46
Rep 582
Sorry for the second post but im looking to purchase ESS flash today, i alrdy have AR dps comming in with wideband and have already in agency power midpipes from my 135i injen intake cpe or stettj charge pipe have both with bov or dual dvs, have an active autowerke fmic but idk if thats going in so im really looking for good power let ESS know im very interested thanks
12-08-2011, 07:27 AM | #11 |
AKA HISSMAN
34
Rep 888
You guys should do some reading in the N54 135i or even 335i sections. There is a lot of valuable information and 100% of every question in this thread has been answered at some point.
12-08-2011, 08:24 AM | #12 |
Rep 110
12-08-2011, 09:02 AM | #13 |
387
Rep 1,571
12-09-2011, 12:58 AM | #15 | |
12
Rep 195
12-13-2011, 06:04 PM | #17 | |
BMW obsessed
9571
Rep 10,855
ESS as a company will not release a product without performing extensive testing and proof, so even though the turbos can be proven on other N54 engines, they are searching for a 1M in particular before moving forward.
12-13-2011, 06:13 PM | #18 |
387
Rep 1,571
The turbos are the same part numbers. If they work on any N54 they will work the same on a 1M. There is no reason to treat it as there is some exclusitivity with the 1M in this regard. My $.02
12-14-2011, 12:31 AM | #19 | ||
435
Rep 2,373
12-24-2011, 05:00 PM | #20 |
Rep 1,075
The 1M has different ecu software and the exhaust system might have less restriction than 135i. The slightly larger 1M intercooler might be another reason they want to test/tune a 1M.
Ordered 4/7/08, Delivered 5/15/08, Sold, but not forgotten.
12-24-2011, 10:07 PM | #21 | |
Rep 2,898
Neil |
12-24-2011, 10:21 PM | #22 |
387
Rep 1,571
The boost control system also seems to have the same hardware. Highly doubt there's anything to be concerned about with the 1M. If success can be had with upgrading on any of the others it will be had on the 1M as well. If the DME turns out to be a little smarter, it will just have to be overcome via flash or piggyback.
