FS: 2007 Bmw 335i Rear w/wavetrac
12-12-2011, 06:02 PM | #1 |
Rep 79
As the title says, I have a 2007 BMW 335 going back to stock and have the rear for sale. The rear has wavetrac LSD installed that will come with it. The rear has about 55k on it and the LSD no more than 500 miles. I am willing to have the cost for the labor of having each of the rears swapped at my shop, Maximum PSI. Shop is located at Linden, NJ. Price: 1000. Will have other parts listed at a later time as they get unistalled. Car is an Automatic Last edited by ricehero; 12-13-2011 at 01:30 PM.. |
12-12-2011, 10:07 PM | #2 |
Rep 777
Explaining what you mean by "rear" would help. Assume lsd won't fit 328i, if it does I'm interested but you'll need to ship; may sound overwhelming but it's been done before...
328i Sports Pkg, Michelin PSS on Staggered 18" OZ Ultraleggeras
. BMS Powerbox. Cyba scoops + Rev motoring intake hose + charcoal delete. Wavetrac LSD . M3: subframe bushings + sways + control arms (fr & rr). Meyle rear toe arms. M3 diff fr bushings . BMW Perf: v2 springs + v1 dampers. Valeo SMFW+clutch. 034 MotorSport engine mounts . Short Shifter + Turner PU bearing + ZHP M weighted shift knob. CDV delete |
12-13-2011, 08:40 AM | #4 |
Rep 155
12-13-2011, 08:49 AM | #5 |
Rep 1,999
Drives: 2007 E92 335i; 2015 X5 50i
This is actually a very good deal. The question more is if it's 6MT or 6AT or if it matters? Good luck with the sale. if it hasn't sold by new years, OP send me a PM.
12-13-2011, 10:18 AM | #7 |
Rep 155
12-13-2011, 05:11 PM | #10 |
Rep 4,499
But you can use it in an AT or MT, because that is what I am running, I have a 335is 6MT and I run the wavetrac AT rear diff.
So if you want to install it in AT or MT it will work.
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
12-13-2011, 06:18 PM | #12 |
Rep 555
Bump for great deall!!
FS: Volk TE-37 SL (Super Lap) 18" Staggered with Tires
http://www.e90post.com/forums/showthread.php?t=739080 |
12-13-2011, 07:49 PM | #13 |
112
Rep 4,771
So you're saying that for $1000 you will pay for your shop to swap the diffs between you and the buyer's car? That is an amazing deal.
If I was closer I would be all over this. |
12-13-2011, 08:42 PM | #14 |
Rep 777
I know some cars have bolted vs. welded diff, plus I'm unclear on manual vs. auto compatibility, on top of (in my case) 335i vs. 328i. If you're the orig buyer you should enlist wavetrac's help for compatibility list, this will help the sale.
Also, you do mean the whole pumpkin then or ?
12-14-2011, 09:48 PM | #16 |
Rep 79
12-15-2011, 07:19 AM | #17 |
Rep 2,558
I live in northern NJ and am interested. Just want to make sure it's compatible with 6mt. And could you let me know what exact parts would be swapped? What do you mean 'rear'... Just the pumpkin? How many miles on your car?
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
12-16-2011, 08:49 AM | #18 |
Rep 79
Just the Pumpkin will be swapped. Car has about 55K miles. According to the wavetrac the LSD is compatible with both MT and AT cars. I am not 100% sure but, I am assuming I have the 30.309.170WK due to the fact that I got it when it was just released.
http://www.wavetrac.net/application.htm |
12-19-2011, 08:53 PM | #21 | |
Real Car Enthusiast
288
Rep 2,082
12-19-2011, 09:10 PM | #22 | |
Rep 4,499
I have a wavetrac AT diff installed in my 6MT 335is, and it works great!
