2010 2011 BMW 5 Series Forum F10 Whining transmission sound in 550i 8SP |
12-15-2011, 01:34 AM | #1 |
Rep 76
Not sure if it's just me or someone else is experiencing the same issue but I'm hearing excessive transmission noise (whining sound) with gears are up/down shifting.
I duplicated this issue, and as well as reported an inconsistent whistling sounds caused by something else to the dealer. They claimed the issue was a result of defective ARS (active roll stabilization) pump which got replaced. Unfortunately the whining noise is still there when I picked up the car today. I'm beginning to think that this might be a transmission issue. Has anyone else dealt with this issue before? Please share your input. |
12-15-2011, 01:57 AM | #2 |
Rep 1,134
I have the 8spd sport transmission (not sure if yours is the sport or not) but I have had no issues with it and I have ran it pretty hard. The ZF transmission is incredible, my recommendation is if you detect a flaw to push hard to have it remedied as it should not leave you second guessing its condition.
2014 550i M-sport
12-15-2011, 08:25 AM | #3 | |
Rep 289
12-15-2011, 01:19 PM | #4 |
Rep 76
I will inquire about the oil pump remedy. However I believe this is a flaw and I'd push till it's resolved. With the radio off, it becomes an annoying noise inside the car!
12-15-2011, 04:32 PM | #5 |
Rep 472
Is it more of a whine or a chirp? My 550i chirps after every gear, it's very audible as others have mentioned the noise (in the cabin and outside the vehicle).
12-16-2011, 01:42 PM | #6 |
Rep 76
12-22-2011, 01:53 PM | #7 |
Rep 15
My GT 550 does this too, it's pretty loud and noticeable and Im deaf in one ear. The 2011 550 Sedan I have does NOT make this noise. Any input would be helpful if this is actually a defect.
12-25-2011, 02:50 PM | #11 |
Rep 76
I didn't get the chance to find out if that was the problem; my car "died" on me yesterday. I got the 'Drivetrain Malfunction' message and the car became non-functional and had to be towed to the nearest dealer. It was xmas eve was they were already gone. Whether or not this had anything to do with the whinning noise, I have a feeling it might be the transmission that went out. It upsets me that they sometimes do not take our complaints seriously leading to such inconveniences.
01-16-2012, 05:06 PM | #12 | |
Rep 76
What should I do with this situation? |
01-16-2012, 09:14 PM | #15 | |
Rep 76
I'm getting pushback because they are not savvy enough to diagnose and fix the issue. They claimed the 750i makes the same noise, but duh I own a 550i, stupid! They want me to come and pick up my car because there's nothing for them to do, and I say not until you prove to me that the noise is normal. |
01-18-2012, 04:24 AM | #16 |
Rep 289
When i got my oil pump replaced,the dealer told me it was the 750i owners who complained first,they thought the 750i should be a lot quieter for the type of car it was,this is when they looked at the oil pump as the problem.
01-19-2012, 01:29 AM | #17 |
Rep 76
Somehow the dealership was trying to push back that it was normal because the 750i makes the same noise. I told them to better find a way to fix it before I pick up my car. Miraculously, a BMW engineer happened to be visiting today so he confirmed that it is indeed the oil pump! So frustrating!!
07-27-2019, 12:32 PM | #18 |
Rep 30
I'm getting a high pitched (but low volume) whining noise on my 530 d xdrive (auto with 140,000 km), but only on deceleration, around 70 - 90kmh - completely silent at any other speeds, and never on acceleration. I've just have the differential oil (front and rear) and transmission oil replaced, no change... Any ideas? Next step is to change the transfer case oil, but I'm not holding my breath that it will resolve the issue... is it possible it could be the pump?
07-27-2019, 12:47 PM | #20 |
535
Rep 1,873
Change the transfer case fluid and see what happens. It could be the transfer case itself - there are a lot more bearings in the driveline than just the transmission.
What you describe is a fairly typical driveline bearing whine off throttle. I had one around 40kph you could barely hear and got a new transfer case under warranty. I had one around 120kph you could hear clearly, I got nothing but a TC oil change and an excuse that it was my "non-standard wheel and tire setup" (which consists of square 351M wheels and BMW spec tires - factory equipment for the X-Drive with M-Sport package, but my X-Drive wasn't M Sport so that's not how it left the factory so that must be the problem... Whatever guys). I'm out of warranty now. The noise is still very faint and often not present. It's not getting worse at any rate. If you're outside of warranty and sound it subtle, your most productive course of action might be to change all the fluids, say a prayer, keep changing them regularly and keep driving until it changes noticeably. |
