Weird codes
12-18-2011, 11:32 AM | #1 |
Cobb Stage 2+/ICarbon/HPF/Stett
40
Rep 488
Weird codes
After some spirited driving today with the new stage 2 ST maps (which are amazing) I got a check engine light and the following codes:
P2ACC P30FF Car is running fine following restart. Ominous? |
12-18-2011, 11:47 AM | #2 |
112
Rep 4,771
Boost leak most likely. Does it happen again if you push the car hard again?
There are other potential issues, like wastegate solenoids but boost leak is the most likely. If I was in Texas right now I'd help you out. |
12-18-2011, 12:20 PM | #3 | |
40
Rep 488
Is it bad to be driving with a leak (if that is what it indeed is) |
12-18-2011, 12:23 PM | #4 |
40
Rep 488
The car still drives great too. I monitored boost and was still hitting 18 psi in 3rd..
12-18-2011, 12:59 PM | #5 |
70
Rep 2,197
Log WGDC and see if it is running high. IIRC it should be at or below 50@WOT after it levels out. Try getting in touch with Cobb through their website, their customer support is top notch from what i've heard.
12-18-2011, 01:32 PM | #6 |
33
Rep 1,029
Check your vacuum lines. I've been having issues Hitting boost target, replaced the two vacuum lines near the oil filter housing and back to norm.
12-18-2011, 03:14 PM | #8 |
40
Rep 488
12-18-2011, 04:31 PM | #9 |
112
Rep 4,771
My lungs are throwing some below pressure codes up on the top of the mountain here
Log it and send it to Rob if you manage to log it when it happens. He'll know. |
