Holy Crap look at all these codes!!!!
12-18-2011, 01:35 PM | #1 |
202
Rep 1,950
Drives: 335i
Went to start my car this is the 2nd day my JB4 has been in since 3 months ago.
i don't usually have it in. car felt like it was running rough check engine light turns on i went and got my Snap On code reader and read the codes i sh*t my pants. turned off the car turnd it back on codes were gone and car ran a bit better. NOTE : i didn't clear the codes just turned off the car then turned it back on Last edited by sammy_0559; 12-18-2011 at 03:17 PM.. |
12-18-2011, 03:14 PM | #3 |
213
Rep 1,780
That's crazy. But I was wondering what kind of code reader it is and where did you get it?
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
12-18-2011, 03:16 PM | #4 |
202
Rep 1,950
Drives: 335i
its a JB4. i bought my JB4 a while back i put it in on occasions. took it to the track yesterday blew up my tranny... turned it on this morinig and now this, but the car engine wise went back to normal
12-18-2011, 03:30 PM | #5 | |
202
Rep 1,950
Drives: 335i
http://www1.snapon.com/diagnostics/us/verus |
12-18-2011, 03:37 PM | #7 |
202
Rep 1,950
Drives: 335i
I was afraid too thats why i have it in occasionally, I'm guessing it just my luck with the car.. but the one reason i bought it is because so many people in this forum have it! and it is a lot faster with a whole lot of performance. but i dunno since i blew up my drive train yesterday i really don't wanna touch the car till i feel a bit better.
12-18-2011, 03:41 PM | #8 | |
18
Rep 632
12-18-2011, 03:46 PM | #9 |
202
Rep 1,950
Drives: 335i
Its kinda my dads.. not mine but i use it a little more than he does
But has anyone seen anything like this? Last edited by sammy_0559; 12-18-2011 at 03:59 PM.. |
12-18-2011, 04:07 PM | #10 |
Rep 1,035
Sammy, focus on the VANOS inlet/outlet faults. This is most likely your issue and will also create misfires. It will also cause boost faults as well.
Can your scanner say what mileage it was set at? If so were the VANOS faults and misfires set around the same time? 2 things to check here. One pull off your oil filter cap. There is supposed to be a long piece of plastic that the filter slides onto, if that is not there, this is causing your issue. If that is there its most likely your VANOS solenoids. Very easy to change if you are not in warranty |
12-18-2011, 04:15 PM | #11 | |
202
Rep 1,950
Drives: 335i
And Thank you SOO much for your helpful Response, i will be sure to update you on what happens, and i will PM you for advice if you don't mind |
12-18-2011, 04:16 PM | #12 |
Rep 1,035
Not a problem man, let me know how it works out.
12-18-2011, 04:47 PM | #13 |
202
Rep 1,950
Drives: 335i
12-18-2011, 05:05 PM | #14 |
BimmerPost Supporting Vendor
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
Yeah $9,000 WOW
That costs more than all my mods put together. It'll probably cost more than all my error codes and damages.
12-18-2011, 05:13 PM | #16 |
Rep 1,035
Unfortunately thats what diagnostic equipment costs, but they do alot, other then just read codes. Plus then you have to pay another 1k+ for model year updates its crazy! $9k is nothing. One ISID for BMW is about $20,000 and most dealers have 10-20 of them.
12-18-2011, 06:17 PM | #17 |
202
Rep 1,950
Drives: 335i
Unfortunately Due to my stupidity....
http://www.e90post.com/forums/showthread.php?t=624762 I Know Its insane, i Cried when my dad told me how much it costed.... |
12-18-2011, 06:21 PM | #18 | |
Rep 1,035
Are you sure the trans is blown and you didnt break the DS, Diff or an Axle? |
12-18-2011, 07:01 PM | #19 |
202
Rep 1,950
Drives: 335i
Im not 100% sure its the Tranny thats what i assumed and what the ppl at the track told me. i should find out tomorrow when i put it on the lift. but if its the DS, Diff or an Axle...it would be much cheaper wouldn't it? Plus I'm doing ALL the labor
12-18-2011, 08:56 PM | #20 | ||
Rep 586
2021 Mercedes G550
2015 X5M 2020 Supra-JB4, DP 2008 M5 with muffler delete-sold 2007 650i-sold 2008 335i-JB4, DP, Meth-sold |
12-18-2011, 09:05 PM | #21 |
202
Rep 1,950
Drives: 335i
12-18-2011, 09:09 PM | #22 |
253
Rep 7,089
Drives: '06 AW 330xi
Yea autologic tools are upwards of 30K and I believe you need to pay a yearly fee for updates aswell.
