Meth Kit?
12-19-2011, 11:43 AM | #1 |
Rep 473
Meth Kit?
So its pretty obvious that most of the cars on here that want big power go Meth or even Meth with bigger turbos, only problem is I find it hard to find out good information on it! Yeah I find a good post here and there when searching, but maybe we should make a Meth Sticky so that people who dont understand it fully can look into it and out way the options they have. For example I use to believe that meth is a no no, but after reading more and more about it seems to be a yes yes for this enigine. Due to its carbon build up and fuel issues. So maybe someone with a good amount of knowlege can post up a sticky maybe of the most FAQ's and give it a good run down. Just an Idea
12-19-2011, 11:48 AM | #3 |
Rep 473
A few questions, like how does it spray is it always spraying or only when at WOT? Also how long does an average tank last? What happens if you run out and have no more meth? I read that people buy devils own meth is that the best option?
12-19-2011, 12:08 PM | #4 | |
3441
Rep 79,211
A lot of your questions depends on the setup. Methanol has a large array of options as one kit isnt necessarily perfect for every setup. A popular setup sprays methanol when it reaches a certain amount of PSI. With a progressive controller it can spray maybe 50% at X psi and 100 psi at Y psi. A tank can last forever if you never exceed the boost required to spray. I would say a spirited driver can make it last 1 night or on average 2 weeks to a month. Although tanks vary in size from 3 quarts to 5 gallons or more. Not only that but certain setups can flow 500ml/min while other setups can flow 1500ml/min. So it all really depends, again. If your tune requires meth and you run out you can potentially blow your engine. However, if you have the proper hardware setup known as fail safes then they protect you from running out of meth. They use flow sensors to read flow, and depending on your setup, they can reduce your boost, cut ignition, cut boost, ETC. I wouldnt say devils own is the best or the worst but its a good kit in most respects. You should use a methanol setup that your tuner recommends ideally as they have maps setup for methanol, failsafes that work with their tune, and hardware they recommend. A devils own kit that is universal can work but it requires a little bit more knowledge then someone new to the scene. |
12-19-2011, 12:14 PM | #5 |
Some dude
92
Rep 1,780
Devils Own has been given the THUMBS DOWN by many of the experienced meth-heads here. Poor quality fittings that leak, etc.
Snow Performance is a well known, highly regarded meth company. Depends on the system as to how/when it runs. Vishnu PWM meth integrated into the Procede box is Pulse-Width-Modulated meth output with a failsafe flow sensor. It uses the windshield washer tank, a custom-modified pump (newest generation), and is complete with all hardware/fittings/nozzles/wiring. Takes about 1-2 hours to install. The PWM pulses a valve rapidly on and off just like a fuel injector to meter the meth flowing into the charge pipe. My 335i is 100% stock except for the Procede V5 and PWM meth kit, and it rips! I really need to get it to a dyno. Burger Tuning also has integrated meth in the JB4. Those systems are not PWM but PPS - variable speed pump to meter the meth flow. It doesn't spray well at low motor speeds. But for 90% of users, that is fine, since meth is most important at full boost/full throttle. And you can also make your own boost-pressure activated meth injection using Snow Performance or others. I chose Vishnu for the PWM meth (helps save meth at part throttle for track use), easy integration into the switchable maps, failsafe (defaults to Map 1 in case of no meth flow/out of meth) and ease of tuning and logging.
RRT
E92 335i/6MT with stuff and things |
12-19-2011, 12:31 PM | #6 |
Rep 473
KK thank you both for the information! I plan on maybe taken the plunge in the spring once I'm FBO. So this information deffinatly helped and Ill continue to keep searching until I fully understand it all the way. I guess I'm going to look into vishnu's kits due to the fact that I already have the procede v5 rev 3. So thank you again JamesM3M5 for also explaining that!
12-19-2011, 12:35 PM | #7 | ||
3441
Rep 79,211
We offer all the popular tunes and their methanol kits too so give us a shout if you are looking for anything. I see that James mentioned that the devils own kit does have leaky fitting and this is true if you use their conventional fittings, especially on high meth concentrations. I still have some devils own parts on my personal car however they have all been upgraded to metal fittings (the best) and working seamlessly, just for the record. |
12-19-2011, 12:47 PM | #9 |
3441
Rep 79,211
12-19-2011, 01:07 PM | #10 |
441
Rep 18,331
Aquamist compression fitting are the best out there hands down...If you go with even Snow the fittings are good since they are all metal, but they are still not better than Aquamist..I have Snow Performance parts, but will be switching slowly over to all Aquamist compression fitting in place of my push fittings.
12-19-2011, 02:02 PM | #11 |
Rep 473
OK so when Im ready get the vishnu kit and then eventually replace the nozzels with metal? Is there any long term bad side effects from using meth? Also If I decide to stop using it eventually can I just keep the kit in the car and run another map. Then say I decide to go to the track one weekend just switch maps and fill her up?
12-19-2011, 04:29 PM | #12 | |
3441
Rep 79,211
It is recommended to change your oil more often when using methanol. Every 5000 miles at a minimum. I actually never see people recommending this but I do to my customers and follow this same practice. Methanol can potentially ruin the integrity of oil although cases are rare. You can change maps at will. Last edited by Jeff@TopGearSolutions; 12-19-2011 at 04:36 PM.. |
12-19-2011, 04:32 PM | #13 | |
Rep 170
yes, you can switch to a non-meth map and then back to a meth map at will.
JB4, Alufelgen SF-71, DCI, VRSF DPs, Meth, AR Meth Elbow, AWE BOVs, Catless Exhaust, BMS OCC, ETS FMIC, ECS Strut Bar, ER Engine Cover, M Sport Steering Wheel Trim, LEDs, 20% Tint, Macht Schnell Spacers, ACS Roof Spoiler, ACS Pedals, ACS E-Brake Handle, Blacklines, M3 Steering Wheel w/DCT Paddles, Gunmetal Kidneys, Black Finisher Rods
12-19-2011, 04:41 PM | #14 |
Rep 170
explain...doesn't the water burn up (turn to steam) in the cylinders ?
12-19-2011, 04:59 PM | #15 | |
3441
Rep 79,211
In theory the meth and water should not dilute the oil and turn it milky as long as everything is warmed up. |
12-19-2011, 05:17 PM | #16 |
Some dude
92
Rep 1,780
And the good thing about JB and Procede is that they have boost limits and meth dependent upon oil temp. I hate waiting for the oil to come up to 180F before boosting, especially since my drive to work is only 20 minutes long and it takes about 10-12 minutes for the oil to come up to high boost temps.
If you're concerned, you can pop your oil cap and check. The oil under the cap is the quickest to turn milky if there is a lot of moisture in the oil. Aquamist - that was the other name I was looking for...
RRT
E92 335i/6MT with stuff and things Last edited by JamesM3M5; 12-19-2011 at 05:37 PM.. |
