BMW i6 single turbo powerband from hell
12-19-2011, 05:56 PM | #1 |
659
Rep 10,587
this is what I want to see out of the kits in developement. This would be an amazing street/track car. Quick spool and huge area under the curve. Boost controller needs a bit more tuning but keeping boost level to redline and you can imagine, hell what they have already is fantastic.
3.0l s50 with Steedspeed t3 manifold, GTX35r. bring it on boys, the n54 can do this.
12-19-2011, 05:59 PM | #2 |
219
Rep 3,012
more day dreaming. I wish. And when that happens we'll all be holding onto supras with nicer interiors
12-19-2011, 06:03 PM | #3 |
69
Rep 1,943
2 year from now. Very possible.
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
12-19-2011, 06:04 PM | #4 |
Some dude
92
Rep 1,780
Yeah but you're only making 340lb-ft at 3500RPM!!!
Just kidding. That's a monster. Amazing what the proper turbo setup on an "old" M50 engine will do. A nice, conservative kit for NASA GTS-4 E36 M3 build will stomp those pesky E46 M3s. Oh crap, I've said too much already...
RRT
E92 335i/6MT with stuff and things |
12-19-2011, 06:14 PM | #5 |
659
Rep 10,587
to add fuel to fire, there are any spinning these motors to over 8k rpms for drag purposes. Add on a large enough turbo and things get really interesting over 7k.
I want this turbo setup.....damn thats a meaty powerband. in a 3100lb car you will smoke just about everything out there.
12-19-2011, 06:22 PM | #7 | |
659
Rep 10,587
just under 24psi peak, looks like its dropping 2-4psi by redline. pump gas timing curve.
12-19-2011, 06:39 PM | #9 | |
659
Rep 10,587
..............M50..........M52 cyl 1.....284cfm.....188cfm cyl 2.....276cfm.....191cfm cyl 3.....288cfm.....201cfm cyl 4.....288cfm.....195cfm cyl 5.....276cfm.....194cfm cyl 6.....284cfm.....191cfm
12-19-2011, 06:52 PM | #11 | |
659
Rep 10,587
and for comparison if you want huge HP here is a recent dyno from Mike Radowski at MaxPsi, he's the man! so far these engines are hitting around 155mph-159mph in the 1/4 w a stock 5 speed tranny....there is more to come.
================================================== ========= Quote:
12-19-2011, 06:52 PM | #12 |
Rep 105
N54 flow numbers are mickey mouse compared to those heads
12-19-2011, 07:33 PM | #15 | |
659
Rep 10,587
also keep in mind this is on a dynojet, it will spool quicker on the road. My non GTX 35r spools to 16psi by 3200. granted though, if this dyno would start spooling around 2500, it would be even nicer, but thats not going to happen.
12-19-2011, 08:02 PM | #17 |
Mad Linux Guru On The Loose
1129
Rep 5,400
Drives: 2008 335i Sedan, 2023 M3
Boost numbers rarely mean anything significant when comparing different engines and even different heads.
Sniz, that powerband looks pretty neat indeed.
12-19-2011, 08:07 PM | #18 |
659
Rep 10,587
could you imagine the owner of a e92 M3 driving this.............
12-19-2011, 08:17 PM | #19 |
Rep 2,291
No, too much TQ, too little sound...
Except that if this car sounded like a big turbo Supra... then a certain part of one's body would swell every time it spooled.
2jZ + RB26 + 4G63 + LS9 + N54 =
12-19-2011, 09:01 PM | #20 |
387
Rep 1,571
Gains will definitely be there whenever we finally get a large single kit available, but I do actually believe the N54 heads are going to require significant amounts of work to put out the big numbers. They really seem to be well matched for the original smallish turbos. Unless there's another better suited casting that can be swapped over instead.
12-19-2011, 10:04 PM | #21 | |
Rep 48
12-19-2011, 10:14 PM | #22 | |
70
Rep 2,197
