Stock DME wiring guide or diagram anyone?
12-20-2011, 08:47 AM | #1 |
Rep 516
So after 5 months I just got my car back, and of course it runs like crap. After the living nightmare I've experienced I didn't expect anything less.
Long story very short, all my JB3 pin-out wiring was ripped apart when my motor was removed through the top of the car. I re-connected everything I could where I think it should be, but it's hard when you start from spagetti instead of one wire at a time during a normal instal. Here's my problem, I'm getting a Boost Deactivation code, and the car feels like it's NA. There are a couple solid yellow wires in there. One of those controls the crank sensor, and the shop plugged one of the yellow wires back into one of the harnesses. They think. They're not sure if they did, nor which wire if they did, nor where. I was also getting Vanos codes when I first got the car back. I swapped with other Vanos sensors and codes did not go away. I cleared codes and reset adaptations and drove. No longer getting Vanos codes, but I am babying the car - they might come back if I open it up. Also getting Lambda code. So I'm not sure if it's a DME wiring issue that's disabling the turbos or something else, and I want to eliminate the DME before handing it over to the dealer. Does anyone know if there are stock DME wiring diagrams anywhere? I searched but did not find. Also I want to remove the JB3 entirely while diagnosing but have cl dp. How bad will the car run w/o any O2 sims? I just ordered a JB4 to instal once all this is sorted out, but not sure how I should run the car in the meantime.
07 e90 335i 13 mk6 GTI 13 f30 335i |
12-20-2011, 02:40 PM | #2 |
Rep 516
ok so i found this from Terry, hopefully i can re-trace from this!
http://www.n54tech.com/forums/showthread.php?t=3040
12-20-2011, 04:15 PM | #3 |
Some dude
92
Rep 1,780
If you really want to dig into the factory wiring diagrams, you will need a WDS - Wiring Diagram Systems DVD. They can be found on ebay bundled with ETK, ETM, TIS, KSD, etc. It's a pain to get working right, needs SVGview (should be on the DVD already), and uses Internet Explorer browser and ActiveX controls.
RRT
E92 335i/6MT with stuff and things |
12-20-2011, 04:23 PM | #4 |
Rep 4,764
Bentley manual
12-20-2011, 04:28 PM | #5 |
Some dude
92
Rep 1,780
Paper manuals are fine, but once you get into the interconnectibility of the factory WDS, it's huge time saver. You can click on the module number, relay designation, connector, etc, and it will take you to a physical location picture, wiring diagram of the connector itself, other inputs and outputs to other sensors / systems, etc. I run to the KSD, not the Bentley, for these modern cars with 50+lbs of wire in them.
RRT
12-20-2011, 04:38 PM | #6 | |
Rep 4,764
