low pressure feul pump sensor replaced
12-23-2011, 01:42 PM | #1 |
Rep 252
I had symptoms of a rough idle the rpms would dip below 500 and spike up.. Espicallly at a long red light, and under heavy acceleration the cel or service light would come on and start bucking and shuddering. I told it to BMW they replaced my low pressure fuel pump sensor.. I might be mistaken but i dont think this the real reason why it\'s doing all of this
? I thought it would be coil/injector related possibly hpfp |
12-23-2011, 01:45 PM | #3 |
Rep 252
12-23-2011, 05:06 PM | #4 |
Rep 252
12-23-2011, 07:59 PM | #5 |
Rep 4,724
I had the same problem. They replaced mine too. It half fixed the problem. It happens less frequently. Some one said it might be leaky injectors. When you first start it up, it burns off the fuel that leaked out while sitting overnight. Does yours do it after its warmed up too?
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
12-23-2011, 10:59 PM | #6 | |
Rep 252
12-24-2011, 12:45 AM | #7 |
Rep 2,760
If its not your HPFP failing, it might also be early stages of LPFP failure symptoms. My pressure sensor and LPFP both failed. LPFP failure is common too, just less common than HPFP failure. The problem with these symptoms is they can be anything in the fuel system or ignition system. Codes for pressure sensor, don't necessarily mean it is the sensor. They test the fuel pressure everything checks out, so they assume your sensor is faulty. Only the spurious low pressure fuel codes are actually being caused by a randomly faltering LPFP.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
