Cobb Stage 1 Sport Map - Safe for California?
12-24-2011, 09:12 PM | #1 |
Rep 14
Hi all, I recently got my Cobb and am loving it. I just started with the Drive map and am very impressed and was curious about trying the Sport map, but I saw Cobb makes special mention in the Fuel Requirements section that Drive was designed for Arizona, California, and Nevada.
Does anyone know why this is? Is our 91 octane fuel of lower quality than the other states or is this based on cimate? Thanks in advance! |
12-24-2011, 09:40 PM | #2 | |
70
Rep 2,197
I dont know if e85 is available in CA, but if it is i'd try out a 20% mix try out sport or even aggresive. If no e85, then try some octane booster(NOS is highly recommended.) Hope this helps. |
12-24-2011, 09:49 PM | #3 | |
70
Rep 2,197
Here's a quote from travis that should help you, cheers.
12-24-2011, 09:57 PM | #4 |
Rep 14
Rader1, thanks a lot for the information! Damn fast reply for Christmas Eve too
I was worried it was an octane problem, but I can believe it - when I had a pretty modded DSM running 25-27psi I had to end up running a direct port meth injection setup to get around it. Here's hoping for that those clever guys at Cobb work out some way to trigger meth injection! Some new kits from Aquamist are looking pretty promising though. |
12-24-2011, 10:26 PM | #5 |
70
Rep 2,197
There are meth kits readily available to integrate into a flash tune. They use a MAP sensor to start spraying meth at a user adjustable PSI.
My understanding of the way the N54 wastegates operate is that when you remove vaccuum they open and dump boost, so any failsafe that will cut vaccuum "should" work fine. However, you'd want to contact an expert to verify something like that. |
12-27-2011, 02:01 AM | #6 |
Rep 14
Rader1, thanks again. Ideally I'd like to see Cobb have full bi-directional integration with a Meth setup to be really safe - after all, these motors are expensive! I used to keep a spare 4G63 motor around just in case I was a bit too ambitious with my tuning... a bit hard to do it with the N54
12-27-2011, 11:53 AM | #8 |
70
Rep 2,197
