How can I know if my Vishnu PWM Meth is working or not
12-26-2011, 11:00 AM | #1 |
Rep 44
My friend and I update the map to 11-25 with pro5v110 Dedicated PWM I/O firmware, now we can't see turn signal illuminate when full throttle, but we can see the meth flow in data log. Could anyone help us?
Thanks. |
12-26-2011, 11:13 AM | #2 |
Rep 7,377
You running the right map? Is it set up correctly in the software?
12-26-2011, 11:22 AM | #3 |
Some say...
239
Rep 4,296
Drives: Fresh
Make sure you're in map 4 and you changed the correct parameters in map 2 like the directions say. Also there will be air in the lines so you can pull the hose off before the flow sensor and jump the boost switch to get most of it out.
I have exhaust and an intake... |
12-26-2011, 11:22 AM | #4 |
Some say...
239
Rep 4,296
Drives: Fresh
12-26-2011, 11:22 AM | #5 |
Some say...
239
Rep 4,296
Drives: Fresh
12-26-2011, 11:23 AM | #6 |
Some say...
239
Rep 4,296
Drives: Fresh
12-26-2011, 11:24 AM | #7 |
Some say...
239
Rep 4,296
Drives: Fresh
Make sure you're in map 4 and you changed the correct parameters in map 2 like the directions say. Also there will be air in the lines so you can pull the hose off before the flow sensor and jump the boost switch to get most of it out. That's also a good way to ensure your pump is getting power.
12-26-2011, 11:36 AM | #8 |
Rep 44
12-26-2011, 12:13 PM | #9 |
Some say...
239
Rep 4,296
Drives: Fresh
12-26-2011, 12:14 PM | #10 |
Some say...
239
Rep 4,296
Drives: Fresh
Holy crap I posted that once, major app fail.
12-26-2011, 12:45 PM | #13 | |
Rep 44
We set Start Boost to 16.5 psi in map 2 and set Methanol Mode to 1, Speed Delimiter to 1, Injection Mode to 31(we saw about 35 in datalog). |
12-26-2011, 04:34 PM | #14 |
Some say...
239
Rep 4,296
Drives: Fresh
I have my injection mode set to 25 if that matters.
12-26-2011, 05:34 PM | #16 |
Rep 462
12-27-2011, 08:36 PM | #17 |
I sweat pheromones
203
Rep 2,103
I had mine set a bit high and it worked at first. Few weeks later, I had to turn it down some. My guess is your injection setting probably has to come down a few ticks too.
01-04-2012, 11:04 AM | #18 |
Rep 44
My technician installed a brand new PWM meth kit in another 335i, the same trouble also happened to that car, we really have no idea about this trouble. Could anyone help us? I wrote email to Vishnu 4 days ago and today but no response.
01-04-2012, 11:09 AM | #19 | |
3441
Rep 79,211
If its installed correctly it should just work. Double check wiring and grounds as well as firmware and maps. After that is sorted be sure to enable the correct injection mode value based on flow and to enable PWM meth in user adjustable as well. It sounds like you had it working? So just lower the value of injection mode some. Last edited by Jeff@TopGearSolutions; 01-04-2012 at 11:14 AM.. |
01-04-2012, 11:11 AM | #20 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Post the logs. I'm having a similar issue where the flow starts off high, and then tapers off for some weird reason. I haven't checked the filter yet. Any thoughts?
01-04-2012, 11:18 AM | #21 |
103
Rep 3,177
01-04-2012, 11:19 AM | #22 |
103
Rep 3,177
Make sure you're in map 4 and you changed the correct parameters in map 2, like the directions say. Also there will be air in the lines so you can pull the hose off before the flow sensor and jump the boost switch to get most of it out. That's also a good way to ensure your pump is getting power.
