PWM install help on REV3 Harness?
12-28-2011, 06:51 PM | #1 |
Rep 44
Decided to install my PWM kit today but have encountered a couple of issues. Unfortunately the guys from Vishnu are only back on the 3rd of Jan so would really appreciate any help on this?
Have got the latest Rev3 harness. The first problem I had was that the new harness does not seem to have a matching small black connector (supplying power and ground to meth flow sensor) as per below? Do I perhaps plug this into the bigger black connector in the harness as per the picture below? Also how do I now connect the 2 black wires from the PWM wiring? The "How to enable Rev3 Dedicated PWM" file in the latest 11-25 files says "Step 2: Now the two wires (one male terminated and one female terminated) will be remaining. The male terminated wire goes to the methanol injection valve. The female terminated comes from the methanol flow sensor. Simply route these wires to the appropriate pin in the Procede harness as described below..." How do I route these as they will not fit into the bigger black connector, does this mean I now need to cut into the green (meth flow sensor) and blue (meth inject valve) wires? Really not keen on cutting! The next question I had was on where I connect the red power wires to the supplied relay. The new harness already has 2 red (power?)wires with female blade connectors, 1 runs directly from the normal red Procede wire that usually joins to the green power connector (so I assume no need to cut this wire anymore? think this may go to terminal 87?) and the other red female blade runs from a slot on the Procede connector side (does this connect to terminal 85 now?), see images below Only other issue is that I will need to extend the red power wire back to Procede as I have a RHD car and ECU box is on the opposite side, this should not be a problem though Last edited by Baracus135i; 12-28-2011 at 07:01 PM.. |
12-28-2011, 07:09 PM | #2 |
68
Rep 1,943
I know that all those wires and sensors can be overwhelming but everything u ask is on the Installation guide, also check out some YouTube videos that would help u out a bit. PM ur numb I can help u out over the phone
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
12-28-2011, 07:36 PM | #4 |
68
Rep 1,943
Oh lol... iPhone app sucks. Didn't see that.
12-29-2011, 02:32 AM | #5 | |
Rep 44
LOL Yep, all the way down in South Africa
Furthermore as shown above there is now no small matching black connector in the Rev3 harness (which is shown in the install guide)? Also there are 2 red wires with red female lugs on the new harness not shown in the guide? Have searched YouTube but could only find Shiv's videos on how to plumb the meth nozzels, nothing on the wiring to a Rev3 harness? Can you perhaps send me a link? Jokes aside I can call you? I dont pay for my company phone which has full international access Already tried calling Shiv but according to their answering machine the folks at Vishnu are all away until the 3rd Last edited by Baracus135i; 12-29-2011 at 02:39 AM.. |
