Is this wastegate rattle??
12-29-2011, 04:05 PM | #1 |
Rep 497
Hi,
Just saw another topic about wastegate rattle lawsuit.... Not sure what it sounds like... But I found a video on youtube.. Is this wastegate rattle?? |
12-29-2011, 05:28 PM | #2 |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
No that isnt wastegate rattle...check out the link I have below..Im not sure how to embed it properly..
http://www.youtube.com/watch?feature...&v=7YEk-aSqBls
PERFORMANCE: JB4 G5 \ Backend Flash \ DCI \ BMS Downpipes \ CX FMIC \ ER Chargepipe \ Synapse BOV \ KW V2 \ Muffler Delete \ CDV \ ZHP Shifter \ Cyba Scoops FUN: M3 Front \ Mtech Rear \ JL 10W6 \ ModMyNav \ V1 Hardwired \ LUX H8 \ Gloss Black Trim \ Gloss Black Roof \ Cyba Quads \ Cyba Mtech Diffuser |
12-29-2011, 05:48 PM | #3 |
Rep 2,334
Wastegate rattle occurs only when you release the gas pedal at 3k+ rpm, and you hear a tin can rattling sound. The sound is a by product of the exhaust gas exitting from the wastegate, a metallic flap that is usually held closed by a rod. When you decellerate the rod pulls back the metallic flap to let the exhaust gas escape. The metallic flap is slightly loose from the factory and almost every N54 has wastegate rattle and it is NOT an indicator of failing turbos.
That "tshick tshick" sound during idle is the fuel injectors. My car also has that sound. |
12-29-2011, 07:32 PM | #4 | |
Rep 497
Thank you guys! So if it is not indicator of failing turbos, then what it indicates? Is it just sound and it doesn't affect any performance or reliability for long term? |
12-29-2011, 07:54 PM | #5 | |
105
Rep 1,133
Shouldnt have any issues...I have wastegate rattle too but honestly its not as bad as some of the videos on youtube...so I'm hoping mine doesnt get worse.. If your under warranty you should take it in and try to get them to reduce/get rid of the noise...wont cost you a dime!
12-29-2011, 10:04 PM | #6 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
If you are referring to the ticking noise, then it is normal. As far as I can tell from the crappy laptop speakers, this is the sound of the injectors on a DI motor. Nothing to worry about!
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
01-02-2012, 02:04 PM | #7 |
Rep 420
this is not a rattle of WG....
in my case both turbo have been replaced by new parts, and rattle is already here on decelaration around 3500 rpm to 3000rpm. so thursday, my dealer will replace vacuum pump !!! |
