12-31-2011, 03:39 PM | #3 |
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
zayzay do you have the open or closed system?
12-31-2011, 04:13 PM | #5 |
Rep 5,730
Drives: BMW i3 rex
01-01-2012, 07:51 PM | #6 | |
Rep 270
http://s1216.photobucket.com/albums/dd380/clcbjc123/1M/ Last edited by Oaktree; 01-01-2012 at 07:57 PM.. |
01-02-2012, 05:04 PM | #8 |
Rep 5,730
Drives: BMW i3 rex
after reading about this for 3 days and gathering info from posts, battles and bla blas im going with the AFE stage II w/ heat shield setup tomorrow w/ **********s.
01-02-2012, 07:08 PM | #9 |
Rep 270
That's where I purchased mine from. Installation is a breeze and the final product quality is good.
01-03-2012, 12:34 AM | #10 | |
Rep 4,848
However, it is only cheap, and doesn't affect performance. The question is what's the delta T with and without the intake after compression.
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
01-03-2012, 08:54 AM | #11 | |
Rep 2,898
FWIW, a vendor (not **********s) that carries AFE intakes told me that the closed system likely produces less hp than the open intakes but is less prone to heat soak. Of course, I've never understood how an air filter has enough thermal mass/density to suffer from heat soak. And, as previously discussed, the additional heat produced by an intake charge that includes heated air from the engine compartment is probably extremely small and may, in fact, be completely offset by the increased efficiency of turbochargers that work less hard to suck in air. Neil |
01-03-2012, 01:17 PM | #12 |
66
Rep 304
Would the open intake only suck hot air at a standstill but once moving its getting fresh cool air? I guess unless your drag racing then it would not matter. I much rather enjoy putting the pedal down after im rolling along in 2nd gear where hot air would not be an issue.
2011 1M Coupe VO
2015 MB GLK 250 Blutec Deez 2016 Ram 2500 Cummins Deez 2001 S54 M Coupe (Sold) 1998 M3/4 (Sold) |
01-03-2012, 07:19 PM | #14 | |
Supreme Allied Commander
3774
Rep 54,154
Drives: F80 M3
The closed AFE intake can better deal with the type of heat mentioned above. |
01-03-2012, 08:20 PM | #15 |
224
Rep 3,094
Its a trade off higher temps higher flow vs lower temps lower flow... which would yield more power? Its an endless debate... how much power is lost as temps increase? How much power is lost as flow is restricted? Where is the ideal middle ground?
01-03-2012, 09:44 PM | #16 | |
3774
Rep 54,154
Drives: F80 M3
Stock intake is good for stock boost levels. At GIAC stage 1 the stock intake has become a restriction. |
01-03-2012, 11:35 PM | #18 |
Rep 5,730
Drives: BMW i3 rex
01-04-2012, 12:00 AM | #19 |
I pass gas for a living.
10
Rep 98
Please post video and impressions
Hey Einser,
Please post a video clip of the engine sound and your impression if there is an increase in power....when you get a chance. Thanks!!! |
01-04-2012, 01:52 AM | #20 | |
224
Rep 3,094
01-04-2012, 02:03 AM | #21 | |
Rep 5,730
Drives: BMW i3 rex
with the AFE and the DVs it feels even more sure footed and quick between shifts. you hear the turbos spool with those DCIs too. the setup was about 900USD installed but worth the bucks imho. |
01-04-2012, 04:00 PM | #22 |
3774
Rep 54,154
Drives: F80 M3
A fan is place on top of the engine in both cases and all GIAC dyne runs to ensure no rising of heated air.
