Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Looking for a Valve Cover Gasket DIY
      01-01-2012, 07:46 AM   #1
Orion4
Drives: 2013 335i Sport Line Sedan
Does anyone have a DIY for replacing the Valve Cover Gasket? Mine is starting to leak and my shop wants about 1200 to do the job.
Done this on my 540, etc and I've got the Bentley's. It doesn't look that difficult- more time consuming.
But a DIY from someone who has actually done this would be helpful.
Thanks
      01-04-2012, 05:01 AM   #2
apkraven
Ukrainian tuner
Ukraine
40
Drives: E90 335i
i would appreciate one too, including the torque moments.
      08-06-2012, 03:33 PM   #3
ceenik
Drives: 07 e92 335i
someone help? need this for my N54
      08-06-2012, 06:01 PM   #4
bmw4lyfe
Drives: '07 E92 335i
It's really all self explanatory the only thing you'd need to find is the torque specs but even that for the valve cover bolts just hand tighten them pretty snug and tight.. I. cant imagine them being over 8 ft lbs I changed an 09 328 wasn't bad took a good couple hours. Just everything you take off or move around put back in there right spots. 335 are known for the amount of hours to do the job. That's why it cost so much money.
      08-06-2012, 06:11 PM   #5
GeorgiaTech335coupe
76
Drives: Black BMW 335i coupe
Damn, $1200 is a rip-off. I'd shop around. I don't believe this is a very easy task, so good luck if you decide to do it on your own.
I had my valve cover gasket done for less than half of that. (Considerably less)
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
      08-08-2012, 11:30 PM   #6
Mox_21
Drives: 2007 335I
I just had this done a few days ago. I was quoted 1100$ from my local dealer. I was lucky because I had my brothers shop do it for a little over 200$. It took the guy around 5 hours to do it so if you want to DIY be careful and good luck.
      11-27-2012, 04:12 PM   #7
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I have a DIY for the E90 N54 valve cover being posted tonight....easy job actually!
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      11-27-2012, 09:43 PM   #8
STONEY_M5
MAAD HEAD
STONEY_M5's Avatar
62
Drives: 2010 X5M 2013 M5
13 F10 M5  [0.00]
2010 X5M  [0.00]
07 335i  [9.26]
How do you know when you need to replace it? What are the symptoms I should look for????
F10 M5 e70 X5M
Sold E90 335i
      11-27-2012, 11:39 PM   #9
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Oil blow by, oil smell in engine bay...if your over 60,000 miles do it, robbeck has some very interesting thought about what a valve cover gasket does. If your gasket is blown it can cuse crankcase pressure issues...oil pressure problems ect.
